[MOD] 1% Battery Mod Aokp/cm9
#21
Posted 08 March 2012 - 02:16 PM
#22
Posted 08 March 2012 - 02:24 PM
huh? instructions are pretty clear in OP. This has nothing to do with master mods.Where dies thus get installed into? Master mods?
you download whichever version your running, move to your sdcard-ext. reboot your phone into recovery (safestrap, or bootstrap), and flash the zip. reboot. & you will be running my custom set of battery icons for 1%systems.
Sent from my dark AOKP [R]AZR using tapatalk
#23
Posted 08 March 2012 - 02:35 PM
yea I did that for ab10...and the battery is still the same one....so I'm confusedhuh? instructions are pretty clear in OP. This has nothing to do with master mods.
#24
Posted 08 March 2012 - 02:54 PM
#25
Posted 08 March 2012 - 02:58 PM
if you booted into recovery, and flashed the battery mod, it should be displaying my set when you reboot. in system settings, ROM control, battery. I know it works because i flash these personally before i upload to make sure both My custom set, and restore back to stock work.yea I did that for ab10...and the battery is still the same one....so I'm confused
#26
Posted 08 March 2012 - 03:00 PM
OK that was my question as to where you make the changes...as in where they were installedif you booted into recovery, and flashed the battery mod, it should be displaying my set when you reboot. in system settings, ROM control, battery. I know it works because i flash these personally before i upload to make sure both My custom set, and restore back to stock work.
#27
Posted 08 March 2012 - 03:10 PM
heh, easy to overlook, but its all in the OPOK that was my question as to where you make the changes...as in where they were installed
#28
Posted 12 March 2012 - 03:48 PM
#29
Posted 12 March 2012 - 11:36 PM
Sent from my DROID RAZR MAXX
#30
Posted 12 March 2012 - 11:39 PM
sorry I broke the links while redoing the OP earlier, all should be fixed in a few minutes. thanks!Links are down
#31
Posted 12 March 2012 - 11:53 PM
#32
Posted 13 March 2012 - 02:01 AM
#33
Posted 14 March 2012 - 12:19 AM
Sent from my dark [R]AZR using tapatalk
#34
Posted 15 March 2012 - 07:42 PM
#35
Posted 16 March 2012 - 06:49 AM
#36
Posted 16 March 2012 - 11:05 AM
#37
Posted 16 March 2012 - 11:45 AM
I tried to flash this on ab12 and ab13 and I always get an install aborted when I try.
Ditto this....on AB 13 got same message then a bootloop...yes using bootstrap
#38
Posted 16 March 2012 - 01:35 PM
#39
Posted 18 March 2012 - 06:44 PM
#40
Posted 19 March 2012 - 12:42 AM
