Whats The Differance Between Axiom Ab5 And Axiom Cm9?
10 replies to this topic
#1 Nickcm1820
Nickcm1820
  • 14 posts
Posted 09 March 2012 - 02:06 PM
i flashing one but idk the differance ha :)
#2 Guest_24v_*
Guest_24v_*
Posted 09 March 2012 - 02:09 PM
One is based on Cyanogenmod9 source, and the other is based upon aokp source. Just 2 different types of roms. Like Ford and Chevy.
#3 dccoh
dccoh
  • 157 posts
Posted 09 March 2012 - 05:35 PM
It seems they share the same issues with data (which seems to be better / less drops with every new build), bluetooth causing issues unless its turned off after a call, not being able to run Barcode recognition apps correctly, etc.
I can't wait to be able to run an ICS rom on a daily basis. I am surprised that more efforts have been put into ics than 2.3.6 roms. I'd love to see more GB roms with more options, until an actual ICS leak comes from Motorola with the correct ICS drivers for our camera, etc.
#4 RAZRblade
RAZRblade
  • 95 posts
  • LocationPA
Posted 09 March 2012 - 10:42 PM
you should just go grab ab11 from droidhive. works much better. camera works
#5 tyrthas
tyrthas
    CassDroid's Personal Stalker
  • 455 posts
  • Twitter:@tyrthas
  • Google+:Ron Becker
  • LocationMissouri
Posted 09 March 2012 - 10:57 PM
I was under the impression camera worked on both. Since hashcode fixed it and he did it for ICS not just AXI0M.
Sent from my AOKP AXI0M [R]
#6 busab
busab
  • 49 posts
Posted 09 March 2012 - 11:24 PM
The front facing camera doesn't work out did they fix it?
#7 tyrthas
tyrthas
  • 455 posts
  • Twitter:@tyrthas
  • LocationMissouri
Posted 09 March 2012 - 11:26 PM
Nope. FFC isn't working. But that's not a big deal for most.
#8 SoLongSidekick
SoLongSidekick
    YOU WILL HAIL!
  • 687 posts
Posted 10 March 2012 - 04:00 AM
Yeah the camera was fixed outside of axiom. And they all have data issues because they're porting ICS from a different phone, but it gets better on all builds with every passing day.
Sent From Optimus Prime
:-D :-D
#9 andlaw
andlaw
    BW ftw!! !!!!!
  • 2,463 posts
  • LocationOH-I-O
Posted 10 March 2012 - 04:38 AM
huh? they fixed the camera and got it fully working, but not in axiom?
btw ab11 is dope as hell, data is amazing! not so great luck on data on boot, but when it does get connected it doesn't/hasn't dropped yet. best rom to date imo.
Sent from my [R]AZR using tapatalk
#10 SoLongSidekick
SoLongSidekick
    YOU WILL HAIL!
  • 687 posts
Posted 10 March 2012 - 09:32 AM
Yes, hashcode got the camera working with his work on IC3.
Actually the main problem i had with ab11 is that the camera FCs alot.
:-D :-D
#11 ddemlong
ddemlong
  • 137 posts
  • LocationPhoenix, AZ
Posted 11 March 2012 - 11:46 PM
On Kejars ICS 8.3 he has the FFC working and people seem pretty happy with the data.
Droid RAZR Rooted
