Hello everyone!
I have a Droid Razr XT912 , and when I plug it to the charger it just shows a white LED nothing else...
I tried all button combinations, soft reset etc.. neither of them helped.
When the phone is turned on, it's not getting any charge...
Maybe there's something wrong with the charging circuit?
Any experiences ?
Thank you, any ideas appreciated
Charging Issue, white light, not charging !
DinkaDanka
, Mar 21 2013 02:32 AM
usb charge white
5 replies to this topic
Posted 21 March 2013 - 02:32 AM
Posted 21 March 2013 - 05:46 AM
Have you tried a different charger and wall vs. usb?
Posted 21 March 2013 - 05:59 AM
Yep, I tried many of them, And I have the original ones also, all gives me the same white LED. I'm running on JB.Have you tried a different charger and wall vs. usb?
And when the phone is plugged in to a PC, it doesn't recognises any USB connection. Doesn't show up on a notification bar that its connected.
I think somehing is wrong with the Micro USB port, or its driver inside the phone itself
Posted 21 March 2013 - 06:01 AM
White light generally means dead battery. There are a few Battery threads in our forum that may work for you, I suggest you search them out. Majormer wrote up a good one.
Posted 21 March 2013 - 06:07 AM
You can try this
Make sure you are plugged into the wall and using the cable that came with your phone
Post #5 Make sure you are plugged into the wall and using the cable that came with your phone
Posted 21 March 2013 - 06:23 AM
Just tried that method, not worked. And I read through a lot of threads, hundreds maybe, can't find a solution. I also charged the phone with a stripped USB cable, but when I power ON the phone, and connect charger, it just doesn't recognizes it. It looks like the battery not accepting charge from the Micro USB port. But otherwise charged with the stripped USb cable, it gives good life, lasts whole day.You can try this
Post #5
Also tagged with one or more of these keywords: usb, charge, white
