Unlocked bootloader, custom kernels and downgrading
36 replies to this topic
#21 Demitri
Demitri
  • 7 posts
Posted 08 April 2013 - 06:55 PM
My last phone was an unlocked Rezound so I wanted to make sure before I did anything like that. I haven't had a moto since the Droid 2 and bootstrapped it for roms.
#22 rad5229
rad5229
  • 5 posts
Posted 08 April 2013 - 07:14 PM
Don't do that!! At this point we have no idea what will happen and it's a good possibility you will brick. After unlocking updates should be done with only with Dev produced files from someone here. Or just upgrading individual stuff like radio, Kernel etc..
I flashed the 4.1.2 firmware files in rsdlite after I was boot-loader unlocked. I edited the xml to flash twrp-recovery instead of moto-recovery automatically, and proceeded to flash supersu.zip. I am still boot-loader unlocked, rooted, and now on fresh 4.1.2. I can't say it wasn't risky but it seemed to work fine for me.
  • ndarmitage likes this
#23 dru21281
dru21281
  • 103 posts
  • Google+:dru21281
  • LocationNY
  • Current Device(s):Razr HD, Droid X, Razr, HTC Rezound
Posted 09 April 2013 - 05:51 AM
I don't think there is any way for moto to re-lock the phones once they are unlocked as of now. In the future they can try but I still think it will be nearly impossible to re-lock the xt926 once unlocked. So now that you unlock it's almost impossible to flash something or take an ota that will re-lock. Someone correct me if I am wrong. The only thing moto can do is prevent new phones from being unlocked with a future update.
#24 Memnoch73
  • 5,016 posts
  • Current Device(s):Pixel 3XL
Posted 09 April 2013 - 05:55 AM
As far as we know at this point I believe you are correct however our fear is that someone unlocked will take a Moto OTA and brick their phone.
#25 ndarmitage
ndarmitage
  • 12 posts
Posted 09 April 2013 - 07:56 AM
This sounds boss. Can you post a link or two showing the download sources for the supersu.zip and twrp that you used? What xml edits were required? Thanks!
#26 rad5229
rad5229
  • 5 posts
Posted 09 April 2013 - 04:51 PM
Sure, You must have the boot-loader unlocked to do this
For the xml edit first you just need to remove the getvar commands; else it will fail every time. Once that is done take the twrprecovery.img out of the zip file at this
and place it into the sbf files folder.
Once that is done open up the xml file and edit line 29 "<step operation="flash" partition="recovery" filename="recovery.img" MD5="xxxxxxxxxxxxxxxxxxxxxxxx" />" change recovery.img to the name of your custom recovery (twrprecovery.img in this case).
Also note that you will need to remove the part that says "MD5="xxxxxxxxxxxxxxxxxxxxxxxx"" as this will have changed as well. (I opted to remove it, you could probably change it if you had the MD5 value.)
I proceeded to flash in rsdlite using the edited xml. I placed the supersu.zip located in this forum
to my sdcard.
Once rsdlite finishes doing its thing, just boot into your now custom recovery and flash the supersu.zip. Reboot and your rooted with custom recovery.
I am confident someone could write a batch/script to do all of this automatically possibly using adb sideload in twrp to flash su without ever putting the .zip on your phone, but seeing as I have absolutely zero programming skills we better leave that to someone more adept than I.
I take no responsibility for what you do to your phone, seeing as we are freshly unlocked and still have a lot to learn about what we can and cannot do, you run any possible risks this may involve. I am just lazy when it comes to flashing, the fewer steps the better imo.
  • anddep likes this
#27 RazrGreg
RazrGreg
  • 37 posts
Posted 09 April 2013 - 07:43 PM
Even if you brick couldnt you fastboot back to any previous build because of being unlocked? Soo worst you can do is soft brick and need to reflash.
#28 ndarmitage
ndarmitage
  • 12 posts
Posted 09 April 2013 - 08:03 PM
to my sdcard.
Thanks man! Nice instructions. Nice to know that the supersu.zip file works to root our phones with no changes. I like this approach because it seems very clean!
#29 razzrmaxx
razzrmaxx
  • 348 posts
Posted 10 April 2013 - 02:35 AM
I hope devs could work on the domestic gsm unlock hack too... so we can take our phones to any company
#30 Demitri
Demitri
  • 7 posts
Posted 17 April 2013 - 06:16 PM
Memnoch, I got froggy earilier today and installed the OTA update.  It didn't brick per se, but it did cause the phone to hang at the boot animation.  So I'm not really sure what happened.  Thankfully I made a Nandroid last Friday.
#31 Memnoch73
  • 5,016 posts
Posted 17 April 2013 - 06:30 PM
Well it's good to know you did not perma-brick. I assume you are still unlocked? Good thing you had a backup although I assume fastbooting back to stock would have worked too.
Thanks for the info. And don't do that again.  :p
#32 Brian
Brian
    Everyday holds a different challenge, how will you meet them?
  • 181 posts
  • LocationAnywhere you Aren't
Posted 19 August 2013 - 12:06 PM
OK, I know that there hasn't been any movement on this thread for awhile, but I gots a question...my bootloader is unlocked...and all of a sudden there is an OTA...eveyone says not to take the OTA, because that will patch the unlocked bootloader and you will be locked again, with no relief in sight...????Am I understanding this right or is my limited knowledge of this stuff getting in the way of clarity?
#33 Memnoch73
  • 5,016 posts
Posted 19 August 2013 - 12:56 PM
You're fine to take the update. It cannot re-lock your bootloader. You will lose root but you can load TWRP recovery again and it will restore root. Note you need Moto recovery to install the update.
#34 dfa1
dfa1
  • 7 posts
Posted 24 August 2013 - 03:47 AM
Not total noob, but certainly not as experienced as many here.
I have a Stock 4.1.2 ROOTED (No TWRP etc. Recovery) Maxx HD S/W: 9.16.9 that I'm holding off on unlocking.  I know the latest July OTA Update S/W; 9.20.1 radio and maintenance update is lurking, so I've protected root with "Rootkeeper", frozen "Updater" app and "Motorola Services" app with Rom Toolbox because I'm uncertain of possible repercussions post July OTA Update based on a few reports I've read on other forums.
I have no interest in flashing custom roms so I can live w/o update if necessary, but would welcome a possible JB 4.2 upgrade is that were to ever happen...not holding breath.
Has anyone with a Rooted and Unlocked Maxx HD XT926 experienced any issues after taking latest July OTA?
#35 livinginkaos
  • 15,103 posts
Posted 24 August 2013 - 09:46 AM
The new update only does four things.
1. Updates the radios.
2. Updates the boot.img
3. Updates the tz "trusted zone"
4. The two above block the root exploit as well as the bootloader exploit.
There is a workaround for root, but not the bootloader. If you take the update as is you will lose the option to unlock.
From My S4 Dev Edition
#36 dfa1
dfa1
  • 7 posts
Posted 24 August 2013 - 01:49 PM
Thank you for reply.  My concerns with OTA are based on a couple other members from other forum recently posted issues after July update and were virgin stock rooted and unlocked.  Here are their posts:
1) "It was a little laggy before the update, I think mainly because of the radio and poor reception. After the update it got much better (I've had it updated for around a month). Then all off a sudden two days ago it got really laggy and yesterday it was freezing frequently"
2) "Lots of Google services has stopped messages. And the text message notification is still buggy. Also ram usage is running a little higher than usual. And there's these extra things running that weren't before the update.  It's just really strange. Some days the phone runs fine. I should mention the Google services has stopped messages happen when using navigation"
I'm confused and curious...
  52.61KB   25 downloads
#37 shiva10
shiva10
  • Locationdharwad, karnataka state, INDIA
  • Current Device(s):datawind ubislate 9Ci tablet
Posted 25 May 2014 - 02:49 AM
Dear sir/madam, I am new to this forum. I purchased a new tablet Datawind Ubislate 9ci. It is a 9 inch no-bluetooth tablet.
Details:
*.Android 4.1.1
*.Rock chip RK2928
*.KERNEL linux version 3.0.36 i was trying to install CWM through mobile odin and ROM manager but my tablet was not supported so i downloaded build.prop editor from google play and changed it to some other cwm recognizable model viz. Samsung, nexus etc. When i was doing the above mentioned procedure, suddenly my tablet is coming up to bootloading and hanging there only and not opening
i went to recovery and tried to do wipe data factory reset but failed to get opened after boot android system recovery(3e) has the following options
1)reboot system now
2)apply update from ADB
3)apply update from external storage
4)update rkimage from external storage
6)wipe data factory reset
7)wipe cache partition
8)recovery system from back up
i tried to do wipe data factory reset 2-3 times but still hanging at boot
i had not made any back up before this bootloop and also tried hard reset by pressing needle at the back please somebody help me to get rid of this problem thank you
