[Request] Project Cheesecake Apk
32 replies to this topic
#21 phatdaddyz01
phatdaddyz01
  • 288 posts
Posted 02 May 2012 - 05:02 PM
Quite simply, trying to find a working link to the that app which we don't speak of APK, the thread started by 0verlord at xda-developers has a broken link. Thanks all.
If you're still looking for this PM me, but FYI it does absolutely nothing on the ICS leaks.
#22 ka1z0ku
ka1z0ku
  • 223 posts
Posted 02 May 2012 - 05:24 PM
Thanks but I have a backup on a couple of hard drives now. And yes, I know there's no updates out which can be installed over the ICS builds.
#23 phatdaddyz01
phatdaddyz01
  • 288 posts
Posted 03 May 2012 - 01:46 AM
I meant the app physically does nothing. When you click on each option if just says "should be good". It doesn't even let you try to change servers. Maybe instead of denying access to their servers Moto figured out how to disable the app on these leaks.
#24 Guest_BDH_*
Guest_BDH_*
Posted 03 May 2012 - 01:50 AM
What software version are you on?
#25 phatdaddyz01
phatdaddyz01
  • 288 posts
Posted 03 May 2012 - 09:54 AM
85
#26 Guest_BDH_*
Guest_BDH_*
Posted 03 May 2012 - 10:15 AM
85
Yeah it won't let you select any options at all unless you are on .181 or .173
#27 phatdaddyz01
phatdaddyz01
  • 288 posts
Posted 03 May 2012 - 11:22 AM
I wonder if Motor/VZW blocked it in these builds?
#28 Guest_BDH_*
Guest_BDH_*
Posted 04 May 2012 - 01:41 AM
It's because you have to be on an actual OTA release to use it.
#29 T3hD0gg
T3hD0gg
  • 85 posts
Posted 18 June 2012 - 12:08 AM
Just FYI, the reason why it doesn't work in the ICS builds is because of a bug in either the su program or the environment within which it runs. I've managed to get it to work with a workaround.
#30 Guest_BDH_*
Guest_BDH_*
Posted 18 June 2012 - 12:12 AM
You got it working on a leak?
#31 superrelaxx
superrelaxx
  • 921 posts
  • Twitter:jasNwa
  • LocationSeattle, Washington
Posted 18 June 2012 - 12:59 AM
From what i read, if you change your ro build number to 181 in the build.prop, cheesecake works fine on a leak.
#32 claps1775
claps1775
  • 596 posts
Posted 18 June 2012 - 05:16 AM
It works on stock rooted 181.
#33 zachjeep
zachjeep
  • 172 posts
Posted 18 June 2012 - 05:24 AM
I have a write up for searching for any leak on 181, small updates and anything really. Haven't been able to use cheesecake on a leak though.
