[AOSP-KERNEL] QCOM 3.4 Kernel Development [06/10: Android Booting - Firmware issues]
#61
Posted 16 May 2013 - 05:48 AM
#62
Posted 16 May 2013 - 11:16 AM
Any updates on the custom kernel, how is the testing coming along?? I know it may take a while to work out all the problems before release. CodeKernal has been running well so far.
+1
Sent from my rooted Droid RAZR Maxx HD using Xparent Cyan Tapatalk 2
#63
Posted 16 May 2013 - 11:36 AM
#64
Posted 16 May 2013 - 02:46 PM
No work has been made on this since the last time Hash updated his OP. There have been no changes as he's been working on the Kindle Fire.
This is not hard to tell. Instead of asking the progress just look at the PUBLIC repo with all of the changes in it. If you want to help hook your phone up to sparkfun and fix the code. It goes over my head. It goes over dhackers head. You have to be a professional coder(or really really really persistent and experienced + smart) like Hashcode to help in this project as of yet(Look at the repo, only jonpry and Hash have contributed).
Sorry if I offended anybody... But seriously its right there. Spend 5 minutes and learn what the status of this kernel is lol
Sent from my Nexus 4 using Tapatalk 2
- lbp102, Gytole, livinginkaos and 6 others like this
#65
Posted 16 May 2013 - 03:28 PM
Will this make the battery life on my original droid last 3 days? lmfao cant wait till it's complete! I heard its going to finally enable xray vision through the camera so I can see naked people. AND it turns it into a transformable toaster so I can slam a slice of bread in my phone in the morning and have toast on the go! can't wait!
- JJT211, PantherHeel93 and brandon71 like this
#66
Posted 18 May 2013 - 08:42 AM
Personally, I'd rather have it make me a cup of coffee.
- Gytole likes this
#67
Posted 23 May 2013 - 02:19 PM
#69
Posted 26 May 2013 - 10:46 AM
#71
Posted 26 May 2013 - 05:55 PM
No no.. I already feel bad enough about my speed on this project.
I'm still here. Just waaaaay delayed on another kernel that I was doing.
Take your time man. We know you do SO much for many communities. Thank you!
- txkssnapper, geekabilly, BytecodeMe and 1 other like this
#72
Posted 27 May 2013 - 09:53 AM
Keep up the good work man, look forward to future updates!
#73
Posted 28 May 2013 - 10:01 AM
I appreciate all the hard work and thank you for reaffirming your support to the project
#74
Posted 28 May 2013 - 10:28 AM
Hooray! This guy is just too awesome.
#75
Posted 28 May 2013 - 08:08 PM
I see new commits Hashcode
- neckchop, SamuriHL and jtommyj like this
#76 Guest_BDH_*
Posted 28 May 2013 - 09:53 PM
Moved from ROM section to Development section, as that is where kernels belong.
#77
Posted 29 May 2013 - 10:47 AM
Updated Post #2 with a new bootlog.
I'm getting to the TWRP screen for a few seconds now, before it crashes out. I can play w/ touchscreen, but I don't have USB up yet.
Lines of note in the log:
SMD driver noting lack of allocation table
<3>[ 0.601617,1] smd_channel_probe_worker: allocation table not initialized
Backlight needs work
<7>[ 0.813825,0] lcd-backlight: invalid backlight type
Not sure what this is
<3>[ 0.815412,0] cont_splash_clk_ctrl: dsi_esc_clk - clk_set_rate failed
Checking this
<3>[ 1.055608,0] wcd9xxx_slim_probe: failed to get slimbus tabla-slim logical address: -6
This SPI error happens on other 3.4 kernels I've seen. I think there's a patch for it
<6>[ 1.126659,1] spi_qsd spi_qsd.0: master is unqueued, this is deprecated
USB probe fail
<3>[ 1.165847,1] msm_hsusb msm_hsusb: udc_probe failed
and then the Android gadget fail after that
<3>[ 1.166641,1] android_probe: android_probe(): Failed to register android composite driver
Ext. SD card error
<3>[ 1.219594,0] mmc1: msmsdcc_slot_status: Failed to configure GPIO 171
Seeing some i2c errors for the gsbi4 device:
<4>[ 1.475263,0] qup_i2c qup_i2c.4: Bus still busy, status 132100
Sensor fail
<3>[ 2.614924,0] lm3556_init_registers: Reading 0x0 failed -110
Missing GPIO setup for headset detect
<3>[ 2.632260,1] msm8960_configure_headset_mic_gpios: US_EURO_, AV_SWITCH gpios not configured!!!
Bunch of failed audio init messages (I can't remember if I merged in audio changes)
<6>[ 2.632351,1] msm_audio_init: Not APQ8064 in SLIMBUS mode
<3>[ 2.632382,1] msm8930_audio_init: Not the right machine type
<3>[ 2.632382,1] msm_audio_init: Not the right machine type
<6>[ 2.632412,1] msm_audio_init: Not APQ8064 in I2S mode
BMS battery issues (probably linked to: <7>[ 28.167862,1] Trying to free already-free IRQ 567 through 562 messages)
<3>[ 28.167648,1] pm8xxx_batt_alarm_threshold_set: threshold value, 0 mV, is outside of allowable range: [2500, 5675] mV
<3>[ 28.167709,1] pm8921_bms_configure_batt_alarm: unable to set batt alarm threshold rc=-22
<3>[ 28.167739,1] pm8921_bms_probe: Couldn't configure battery alarm! rc=-22
<4>[ 28.174118,1] pm8921-bms: probe of pm8921-bms failed with error -22
<3>[ 28.177048,0] power_supply usb: driver failed to report `present' property: 4294967274
- LunaticSerenade, BytecodeMe, SamuriHL and 7 others like this
#78 Guest_BDH_*
Posted 29 May 2013 - 10:49 AM
Nice progress sir!!
#79
Posted 06 June 2013 - 03:34 AM
What was the thing I saw last night on twitter with getting non crashing boot of twrp? I think Dhacker posted it.
#80
Posted 11 June 2013 - 02:24 AM
