Best Answer matjmonk , 23 April 2013 - 04:22 AM
Is anyone else having issues with their compass after the upgrade to Jellybean. My compass is close to 180 degrees off after the upgrade which makes navigation impossible. Any ideas how to fix this would be appreciated.
Usually, there is an option in the compass app to allow you to calibrate it, if not, you can get the GPS Utility from the Play store (it's free) and under the tools menu, it has an option to calibrate your compass.
Go to the full post
