Turn by Turn Navigation mot working
GPS Navigation
Best Answer tmyinc , 10 May 2013 - 01:28 PM
Go to stock ROM and try this. https://play.google....chibo.gpsstatus<br /><br />Rule of thumb for me was to dump gps data then get a lock on gps before flashing any cm or aokp based ROM.<br /><br />Sent from my XT907 using Tapatalk 2<br /><br /> Go to the full post
4 replies to this topic
#1 moksha51
moksha51
  • 144 posts
  • LocationBoston, MA
Posted 10 May 2013 - 12:50 PM
My GPS would not lock for Navigation. I can see maps and local apps work with no issues.
I've used the AOKP Aviator ROM , the CM 10.1 RC1 & the RAZR M port.  It was fine before using the first two mentioned ROMs. I tried Stock as well, no luck. Anybody else having this issue??
#2 Memnoch73
  • 5,016 posts
  • Current Device(s):Pixel 3XL
Posted 10 May 2013 - 01:18 PM
I'm thinking your best bet is to use the Utility and go back to start fresh.
I have seen many people with GPS issues in the CM threads. Could be the root of your issue
#3 tmyinc
tmyinc
    Resident Insomniac
  • News Writer
  • 1,276 posts
  • Twitter:TMYINC
  • LocationPA
Posted 10 May 2013 - 01:28 PM   Best Answer
  • moksha51 and Memnoch73 like this
#4 moksha51
moksha51
  • 144 posts
Posted 14 May 2013 - 12:35 PM
That app worked from me from the CM side . I did not have to go to stock. Thanks.
  • tmyinc likes this
#5 tmyinc
tmyinc
    Resident Insomniac
  • News Writer
  • 1,276 posts
  • Twitter:TMYINC
  • LocationPA
Posted 14 May 2013 - 08:02 PM
Awsome! Glad it helped. Sometimes its useful to dump gps data every once in a while.
Also tagged with one or more of these keywords: GPS, Navigation
