Best Answer kaos2569 , 29 April 2013 - 03:04 PM
Hey everyone. I figured out the problem!!!!
I made a charge cable because the battery went totally dead and I figured I would spend my weekend attempting to fix this sucker.
I used Matt's utility and re-flashed again. NOTHING!!! I decided to take the phone screen off and disconnect the battery and use the charge cable only and see what would happen if I did the whole process with just the cable-no battery connected.
JACKPOT!!! 4.1.2 loaded. Reboot. Check. Boot into Recovery. Check! Everything works!!
Re-connect the battery-BOOTLOOP.
Thank you Aixelsyd and Tucstwo for the the help and sorry for making you guys crazy! And THANK GOD it was the battery. I was about to stop messing with phones thinking I lost it. Gonna order a battery and get this thing back to working order.
Go to the full post
