[KEXEC] Code Kernel 4/27/13
KEXEC Bytecode kernel
85 replies to this topic
#1 BytecodeMe
BytecodeMe
    Private Pile
  • 2,004 posts
  • Twitter:@BytecodeMe
Posted 22 April 2013 - 09:04 PM
This is my first released kernel ever! :)
WILL ONLY WORK ON AOSP ROMS!
Features:
Frequency slot and other CPU tweaks
Custom voltage control
ROW scheduler
Pegasusq governor
Fsync turned off with toggle
Miscellaneous I/O tweaks
Problems:
None known
To come:
More tweaks to make smoother/ better battery life
Changelog:
R2 4/23/13:
Fixed some stability issues by reverting some commits
R3 4/24/13:
The fix for min frequency being stuck at 300Mhz; is now 150Mhz
Disable GENTLE_FAIR_SLEEPERS
Entropy tweaks
Lowered CPU transition latency
Updated Targa defconfig for compiliong for them
Latest commits from upstream CM kernel
R4 4/27/13:
Modified Smartrelfex driver
OCable to 1400Mhz
CPU OC and control
Disabled some Memory debugging
Set  fsync on for stability but decrease in I/O performance
Many more CPU governors
Many more Schedulers
R5 4/29/13:
Boot up at 1200Mhz still OCabe to 1.4
Disabled some governors and schedulers
Disabled some debugging
 I HIGHLY RECOMMEND INSTALLING TRICKSTER MOD TO MODIFY KERNEL SETTINGS!
DO NOT TOUCH ANYTHING UNDER SMARTREFLEX OR CORE OC IT IS VERY LIKELY YOU WILL DAMAGE YOUR PHONE PERMANENTLY!!!
 I AM NOT RESPONSIBLE FOR ANYTHING THAT HAPPENS TO YOUR DEVICE!
Thank you:
dhacker29
Hashcode
dtrail
franco
faux123
imoseyon
Hero_Indeed
  • mugsy77, lownslow200sx, BigJArm and 7 others like this
#2 dhacker29
dhacker29
    CM Master
  • 49 posts
  • Twitter:dhacker29
  • Google+:davidhackerdvm@gmail.com
Posted 22 April 2013 - 09:26 PM
Nice to see options ;)
  • PillClinton, Hero_Indeed, BytecodeMe and 2 others like this
#3 BytecodeMe
BytecodeMe
    Private Pile
  • 2,004 posts
Posted 22 April 2013 - 09:30 PM
Can't believe I forgot to add you guys to my thanks list. Added :)
#4 Guest_BDH_*
Guest_BDH_*
Posted 22 April 2013 - 09:43 PM
Nice work Byte!
  • BytecodeMe and Gytole like this
#5 ryankliber
ryankliber
  • 103 posts
Posted 22 April 2013 - 09:56 PM
Doesn't boot for me running liquidsmooth 2.2.1
#6 BytecodeMe
BytecodeMe
    Private Pile
  • 2,004 posts
Posted 22 April 2013 - 09:57 PM
I know that dtrail's JBX kernel doesn't boot on Liquid Smooth either. But redownload, I did some after post unannounced change ups. :p
#7 BytecodeMe
BytecodeMe
    Private Pile
  • 2,004 posts
Posted 22 April 2013 - 10:20 PM
DOH! Forgot to mention this is on the newly reverted 3.0.8 kernel source! Have to be on nightly 4/22 and on!
  • ryankliber likes this
#8 Rootuser94
Rootuser94
    Touchwiz Overlord
  • 1,019 posts
  • Twitter:@Rootuser94
  • LocationPA
Posted 23 April 2013 - 05:50 AM
Nice work brother!
#9 cmh714
Posted 23 April 2013 - 06:04 AM
Nice to see you back and being revitalized Byte. Keep up the good work
#10 Hero_Indeed
Hero_Indeed
    Android Rescue Squad
  • 173 posts
  • LocationMinnesota
Posted 23 April 2013 - 06:49 AM
I am amazed on a continual basis at the work you guys push out. I tip my hat to ya, Byte.
#11 BytecodeMe
BytecodeMe
    Private Pile
  • 2,004 posts
Posted 23 April 2013 - 06:58 AM
Updated to fix some stability issues caused by writing dirty data to disk while screen on by franco. Fixed.
#12 ddmclw
ddmclw
  • 10 posts
Posted 23 April 2013 - 07:31 AM
Where do you access it. I see no program to do so? Kernel version says "unavailable" in about phone.
#13 BytecodeMe
BytecodeMe
    Private Pile
  • 2,004 posts
Posted 23 April 2013 - 09:32 AM
The kernel runs on your phone after you've flashed it. You'll see the affect in performance and battery life whether they be good or bad. You just flash the zip and it's all done for you.
#14 ddmclw
ddmclw
  • 10 posts
Posted 23 April 2013 - 10:25 AM
Ya sorta figured that. Didnt know if i was missing something and thought it might be like the jbx kernel. Installed it this morning and everything running good! Thanks looking forward to more!
#15 BytecodeMe
BytecodeMe
    Private Pile
  • 2,004 posts
Posted 23 April 2013 - 06:35 PM
So how is she running guys?
#16 ddmclw
ddmclw
  • 10 posts
Posted 23 April 2013 - 07:21 PM
Great! No problems so far. Ran all day. Battery seems to be good also. Thanks for your work :)
#17 androidlearner
androidlearner
  • 904 posts
  • LocationPeoria, AZ
Posted 23 April 2013 - 07:29 PM
I would test this but i can't find any ROMs here that look like they still are supported by the devs :(
Sent from Maximized FlyingPlatyRazrJellyRaptor
#18 BigJArm
BigJArm
  • 212 posts
  • LocationIdaho
Posted 23 April 2013 - 07:37 PM
Anyone try this with AOKP yet?
#19 BytecodeMe
BytecodeMe
    Private Pile
  • 2,004 posts
Posted 23 April 2013 - 07:38 PM
You could always run CM nighltlies. Get them at
Every time a commit is made CM will build it and show it there :)
  • PillClinton and livinitwarrior like this
#20 BytecodeMe
BytecodeMe
    Private Pile
  • 2,004 posts
Posted 23 April 2013 - 07:41 PM
I haven't. I don't know if AOKP has had a nightly/build using the 3.0.8 kernel. May have to wait for that.
Also tagged with one or more of these keywords: KEXEC, Bytecode, kernel
