Help with RSD for Razr M
RSD Razr M
Best Answer RikRong , 23 April 2013 - 07:44 AM
When I RSD'd I used version 6.1.4, the earlier versions wouldn't work and left me with a "fastboot flash failed" phone.  When connected, my device info wouldn't show in RSD, but it would show that something was connected.  I pushed the files and everything worked.  FYI, if you need to fastboot I would suggest using Matt's utility, it's far easier than RSD.
http://www.droidrzr....indowsmaclinux/
Go to the full post
4 replies to this topic
#1 webtrix
webtrix
  • 77 posts
Posted 23 April 2013 - 07:02 AM
Hi! Does anyone know why i cant get rsd to see my razr m. i have tried everything. different versions, different cable, run as admin, latest drivers. computer sees phone, but not rsd. After I unlocked bootloader, i lost my restore while trying to get eclipse to work.
thanks,
brad
I have used this pc before with my Droid X2 and it worked fine.
#2 RikRong
RikRong
    Cap'n Slow
  • 2,117 posts
  • LocationNoDak
  • Current Device(s):Pixel 7
Posted 23 April 2013 - 07:44 AM   Best Answer
#3 webtrix
webtrix
  • 77 posts
Posted 23 April 2013 - 08:28 AM
i tried matt's utility, but now i realize i used the wrong one. i didnt run the dev since my bootloader is unlocked. i will try that now and let you know. thanks.
#4 webtrix
webtrix
  • 77 posts
Posted 23 April 2013 - 09:03 AM
this version worked great! tyvm.
  • RikRong likes this
#5 RikRong
RikRong
    Cap'n Slow
  • 2,117 posts
  • LocationNoDak
Posted 23 April 2013 - 06:52 PM
NP, glad you got it fixed.
