[Theme] Ic Blue Edge For Moto Ics Leak
Posted 06 April 2012 - 09:03 PM
Credits
Thanks to arcanexvi for bringing us the Moto ICS leak
And big thanks to Vicious for finding a way for all of us to get back to ICS.
A few things first.
1.If you loop you will have to rsd back to GB and make your way back to ICS leak ( I tested theme and worked for me)
2.You should have latest razr bootstrap v2.0 (have not test earlier version).
3.As most of you know there is a bug with battery when you either power off the phone, reboot or flash anything in clockwork. When you boot up the stats will be off. Best bet is to make sure you have full charge, flash theme and just let it run and at nighttime and just put it in charger while phone is on and by morning it should balance out..
4.And of course you have to be on the Moto ICS leak for this.
5.I am also putting out a revert to ICS moto stock zip.
I am not responsible if you soft brick your phone and you have to rsd back to GB, and you have to make your way back to ICS!!! You take full responibility.
Now here is IC_BlueEdge
268.88KB 86 downloads 75.38KB 92 downloads 66.99KB 74 downloads 58.6KB 52 downloads
49.09KB 37 downloads 100.33KB 31 downloads 97.4KB 30 downloads 68.25KB 26 downloads
68.97KB 22 downloads 69.34KB 16 downloads
What was themed
The usual, but the main ones are
Framework (mostly)
SystemUI
Settings
Phone
Contacts
and others(flash theme to see what else was themed)
IC Moto BlueEdge Final - no longer supported
Revert to ICS Moto stock - no longer supported
- mugsy77, VantenKiest, mlwald79 and 7 others like this
#2 Guest_BDH_*
Posted 06 April 2012 - 09:14 PM
Wow, 84.7 megs lol!!!!
Posted 06 April 2012 - 09:15 PM
No prob, enjoy!!!Awesome!!! Downloading and flashing now. Will report with errors or suggestions (if any). Thanks man!!!
#4 Guest_droidpcguru_*
Posted 06 April 2012 - 09:30 PM
#5 Guest_BDH_*
Posted 06 April 2012 - 09:35 PM
1. Notification pulldown still has a ICS colored bar at the top of where the notifications are, same bar is at the top of the dialer as well.
2. Little circle by the notification pulldown handle is still ICS colored
3. Battery icon is still ICS colored
4. Background of "incoming" text message is still ICS colored
5. When an option is activated on the power menu widget, the bar at the bottom is ICS colored
That's pretty much it man. Vert very nice job on the theme! Can't wait to see the next update!!!
Posted 06 April 2012 - 09:37 PM
Posted 06 April 2012 - 09:38 PM
Any time you need a tester just let me know.
Posted 06 April 2012 - 09:43 PM
Ok, things I've noticed so far (even though I'm sure you're aware of these):
Battery icon shouldnt be ICS color, I made those icons myself. The rest is about 90% related to framework,(which is not playing nice, lol). The rest I can work on for next update.Just wanted to put something for you all
- The Kid likes this
#9 Guest_BDH_*
Posted 06 April 2012 - 09:46 PM
Do you think I should mount /system in recovery? Might help lol, wouldn't hurt at least.
Posted 06 April 2012 - 09:49 PM
Shouldn't. Post a screenshot with battery icon.Do you think I should mount /system in recovery? Might help lol, wouldn't hurt at least.
I should mention that i did not do battery charging icons.
#11 Guest_BDH_*
Posted 06 April 2012 - 09:52 PM
That was it lol, unplugged the charger and now the battery icons are good. Are they 1%?
Posted 06 April 2012 - 09:54 PM
No, 10% up til 20 then 15, 13, 10 and 5 (not sure why 13 shows, lol) Going to try something next update.That was it lol, unplugged the charger and now the battery icons are good. Are they 1%?
#13 Guest_BDH_*
Posted 06 April 2012 - 09:56 PM
Lol 13%, seen a supposedly working 1% battery mod for the leak on XDA, want the link?
EDIT: Here it is, I haven't tried it so I can't verify.
Posted 06 April 2012 - 10:03 PM
Maybe, Going to edit battery myself first, I can make the changes but I have to see if the system will show. May not display on lockscreen or in battery settiings but might show it through battery icons. Worth a shot, lol.Lol 13%, seen a supposedly working 1% battery mod for the leak on XDA, want the link?
#15 Guest_BDH_*
Posted 06 April 2012 - 10:05 PM
Hey just keep doing whatever you're doing man, love this theme. I'll be bringing some of mine over from the LG Revolution as well. Can't compete with yours but I like them lol. Here's a link to my site:
Posted 06 April 2012 - 10:16 PM
Those look good, I like them.Hey just keep doing whatever you're doing man, love this theme. I'll be bringing some of mine over from the LG Revolution as well. Can't compete with yours but I like them lol. Here's a link to my site:
Its not about competing, its about doing something you like and sharing it with others.From there its a personal preference for others.
Posted 06 April 2012 - 10:42 PM
RAZR No Longer. Currently running the LG G2 and HTC One (M8)
Time for Moto to update the line!
Posted 06 April 2012 - 10:47 PM
Enjoy!!Thanks Wulf. Downloading now!
Posted 07 April 2012 - 10:25 AM
Posted 07 April 2012 - 11:06 AM
Good to know. Thanks for the infoI installed the 1% battery mod this morning and have been watching it. While it did change the icon to a circle, it does not display in 1% increments.
