[Script] Th3Ory's Cmplx|Ics Leak|Modifier
#1 Guest_BDH_*
Posted 08 April 2012 - 11:32 AM
ICS Roboto Clean Font
FULL INIT.D Support
CMPLX Script Set (Speed, Fluidity, Battery Life, RAM Management)
Max FPS (240)
Cron
Force Home Launcher in GPU (Software)
Disable Kernel logging (Speed)
Max JPEG resolution to 100%
SD Read Speed
Zipalign At Boot
Kernel Tweaks
Shorter Ring Delay (Connect Call Faster)
Proximity Sensor Hack (Light Up Faster)
Go to his thread and make sure you click "Like This" and tell him Thanks!
Posted 08 April 2012 - 12:25 PM
Posted 08 April 2012 - 12:35 PM
#4 Guest_BDH_*
Posted 08 April 2012 - 12:39 PM
Does this need to be flashed with the ics bootstrap?
Yes, ONLY the ICS Bootstrap.
Posted 08 April 2012 - 03:38 PM
Posted 08 April 2012 - 05:21 PM
Sent from my DROID RAZR using Tapatalk 2 Beta-5
Posted 08 April 2012 - 06:22 PM
Where can you get the ics bootstrap
Within the same forums here under development
Posted 08 April 2012 - 06:27 PM
Posted 08 April 2012 - 06:49 PM
I backed up stock, ran this script, rebooted and ended up unrooted. So I restored my back up and booted up with NO SCREEN. Nothing. Just bootloop with vibrate. Worse than bricked. I am actually RSD'ing back to stock .744 all over. Anyone know WTF I did wrong? This totally sucks
I'm thinking that restoring is not an option yet, even with the icsbootstrapper. As far as root, you could try other techniques to restore such as the terminal commands that DH discovered.
/system/su-backup
mount -o rw,remount -t yaffs2 /dev/block/system /system
cp /system/su-backup /system/bin/su
#10 Guest_BDH_*
Posted 08 April 2012 - 06:58 PM
Thanks so much! Did you include the 3G speed tweaks?
You're very welcome but this is definitely not my script, droidth3ory made this for us and I just simply posted here.
/system/su-backup
I have tried and tried many times to restore a nand backup and restoring system always fails. You are absolutely correct, nand restore does not work. Despite the fact that it say it does in the OP for the recovery.
Posted 08 April 2012 - 09:41 PM
Posted 08 April 2012 - 09:48 PM
Question for you: Do you use Voodoo to protect your root? If so, before booting into recovery & attempting to restore your nandroid backup, open Voodoo and delete your backup of root. This has caused issues for me previously! Let me know if this works for you
Edit: Confirmed by other users that this works! &
Posted 09 April 2012 - 07:45 AM
Posted 09 April 2012 - 07:58 AM
Thanks! Also since the script install my battery died. When i plugged it in the device froze on the moto screen and wasn't charging the battery. Anyone else experience this
Posted 09 April 2012 - 08:30 AM
Sent from my XT912 using safestrap and ATM ics
Posted 09 April 2012 - 11:14 AM
Posted 09 April 2012 - 11:22 AM
This happened to me, all you need to do it hold power and down volume to shut it off and then turn it back on, it should boot up normally.Thanks! Also since the script install my battery died. When i plugged it in the device froze on the moto screen and wasn't charging the battery. Anyone else experience this
Posted 09 April 2012 - 01:58 PM
Agreed, mine freezes on the Motorola Dual Core screen at boot but another hard reboot fixes it. Weird bug, hope DT can solve it.
Sent from my Droid RAZR (Stock Rooted 4.0.3 ICS) using Tapatalk 2 beta 5
#19 Guest_BDH_*
Posted 09 April 2012 - 04:00 PM
Posted 09 April 2012 - 07:13 PM
My phone actually froze after letting charge all night. So rebooted it and it got stuck on the moto logo. I had to press power and volume twice to get it to boot. What a scare
