[Script] Th3Ory's Cmplx|Ics Leak|Modifier
36 replies to this topic
#21 mlwald79
mlwald79
  • 45 posts
Posted 10 April 2012 - 04:40 AM
My phone actually froze after letting charge all night. So rebooted it and it got stuck on the moto logo. I had to press power and volume twice to get it to boot. What a scare :wacko:
Same issue here.
#22 theFix2012
theFix2012
  • 64 posts
Posted 10 April 2012 - 12:00 PM
Question for you: Do you use Voodoo to protect your root? If so, before booting into recovery & attempting to restore your nandroid backup, open Voodoo and delete your backup of root. This has caused issues for me previously! Let me know if this works for you
Edit: Confirmed by other users that this works!
What is the proper method for doing a restore? What should be wiped, etc. ? I really don't feel like redoing this ICS thing. :o
Sent from my MAXXED out ICS!
#23 quangtran1
quangtran1
  • 243 posts
Posted 10 April 2012 - 12:34 PM
I can replicate my problems time and time again with this modifier. I've tested this modifier with both of my Razr Maxx phones and I get the same results: 1) Titanium Backup backup tasks do not finish; instead, they hang at all different places (5%, 8%, 12%, etc...); and 2) SQLite Editor also hangs. I've reflashed 6.12.173 and started all over, flash ICS, etc... everything always works fine until I flash this modifier. That's ok, no big deal, just wondering why. Thanks.
#24 chavist
chavist
  • 69 posts
Posted 10 April 2012 - 12:49 PM
I am not sure if this is the script, but it took my phone 7 hours to charger to 100 percent today. Before it would charge in about 3. Anyone know how to uninstall
Sent from my DROID RAZR using Tapatalk 2 Beta-5
#25 pdumont1
pdumont1
  • 19 posts
  • Twitter:@puffingonj
  • Google+:Patrick Dumont
  • Locationct
Posted 10 April 2012 - 12:55 PM
u either have to fastboot back and reinstall ics or hopefully u made a backup before running the script int that case just restore
gs3 with "unauthorized software"
#26 theFix2012
theFix2012
  • 64 posts
Posted 10 April 2012 - 01:00 PM
I made a backup. That's what I'm asking, what is proper restore method. Do I do any wipes or anything?
#27 pdumont1
pdumont1
  • 19 posts
  • Locationct
Posted 10 April 2012 - 01:04 PM
Make sure u delete your su backup through voodoo and then just boot into recovery and restore
#28 theFix2012
theFix2012
  • 64 posts
Posted 10 April 2012 - 01:05 PM
Thanks! :unsure:
#29 pdumont1
pdumont1
  • 19 posts
  • Locationct
Posted 10 April 2012 - 01:06 PM
any time!! :D
#30 theFix2012
theFix2012
  • 64 posts
Posted 10 April 2012 - 02:24 PM
any time!!
All went well. I'm fully restored. To be honest, and in no way any offense to DT, on my phone its smoother and less problematic stock, debloated.
#31 chavist
chavist
  • 69 posts
Posted 10 April 2012 - 02:57 PM
Another issue is the script disabled smart actions
#32 pdumont1
pdumont1
  • 19 posts
  • Locationct
Posted 10 April 2012 - 03:58 PM
i dont use smart actions not a big fan. i think someone else said something about ti not working either
#33 quangtran1
quangtran1
  • 243 posts
Posted 11 April 2012 - 04:18 AM
I love Smart Actions. I used Tasker since its release and had 20+ rules, but that app used too much battery. Sure, Tasker is more programmable and flexible than SA, but SA is cleaner and not a battery hog. One aspect I miss about Tasker though is its abilibty to turn on/off GPS only when I execute certain apps (Navigation, Poynt, etc). By the way, SA worked for me even with the DT modifier.
#34 BigJArm
BigJArm
  • 212 posts
  • LocationIdaho
Posted 11 April 2012 - 05:49 AM
My TiBu is working fine.
#35 chavist
chavist
  • 69 posts
Posted 25 April 2012 - 03:59 PM
Has this script received an update to fix any bugs?
#36 theonlycosmic
theonlycosmic
  • 470 posts
  • LocationCalifornia
Posted 25 April 2012 - 04:40 PM
No. DT has been mourning for the past week and I believe he is back but needs to get caught up and such. This script works great if you know what you are doing. Make sure you have the correct busybox installed(1.20), update your binaries via superuser, and delete your su-backup. Those are the key ones. Also, if you have superuser problems, make sure you have a backup of su and run terminal emulator and run commands for restoring root. Just look in the How-to section I believe for the commands.
#37 garywojdan81
garywojdan81
  • 633 posts
  • Twitter:gwojdan_81
Posted 25 April 2012 - 05:26 PM
Smart actions works for me.
