[Theme] Darkedge For Moto Ics Leak
Posted 16 April 2012 - 05:13 PM
Credits
Thanks to arcanexvi for bringing us the Moto ICS leak
And big thanks to Vicious for finding a way for all of us to get back to ICS.
A few things first.
1.If you loop you will have to rsd back to GB and make your way back to ICS leak ( I tested theme and worked for me)
2.You should have latest ICS bootstrap ( v2.0 will work to flash but not for backup/restore).
3.As most of you know there is a bug with battery when you either power off the phone, reboot or flash anything in clockwork. When you boot up the stats will be off. Best bet is to make sure you have full charge, flash theme and just let it run and at nighttime and just put it in charger while phone is on and by morning it should balance out..
4.And of course you have to be on the Moto ICS leak for this.
5.I am also putting out a revert to ICS moto stock
I am not responsible if you soft brick your phone and you have to rsd back to GB, and you have to make your way back to ICS!!! You take full responibility.
Now here is IC_Moto DarkEdge
283.75KB 84 downloads 336.13KB 77 downloads 289.64KB 59 downloads 64.72KB 49 downloads 59.67KB 40 downloads
68.95KB 28 downloads 62.28KB 18 downloads 91.09KB 13 downloads 226.77KB 18 downloads
59.61KB 18 downloads
What was themed
The usual, but the main ones are
Framework (mostly)
SystemUI
Settings
Phone
Contacts
and others
DarkEdge theme for Moto ICS leak - no longet supported
Revert to Moto ICS leak stock - no longer supported
- nix80908, andlaw, pdumont1 and 7 others like this
#2 Guest_BDH_*
Posted 16 April 2012 - 06:14 PM
Posted 16 April 2012 - 06:18 PM
Posted 16 April 2012 - 06:39 PM
- andlaw likes this
#5 Guest_BDH_*
Posted 16 April 2012 - 06:52 PM
Lol, hope you all enjoy it.
I know I will, this theme will be on my phone for quite a while! Thanks again Wulf for everything you're doing here! Downloading now!
- andlaw likes this
Posted 16 April 2012 - 08:30 PM
#7 Guest_BDH_*
Posted 16 April 2012 - 09:18 PM
Does this have battery percentage in increments of 1%?
No.
On a side note, thanks again for this theme Wulf! Best theme out for the leak hands down!
Posted 16 April 2012 - 11:41 PM
What about a deep purple theme? No homo but deep purple in ICS form would be pretty sexy.
Posted 17 April 2012 - 12:03 AM
Posted 17 April 2012 - 12:30 PM
Posted 17 April 2012 - 04:48 PM
Posted 17 April 2012 - 07:44 PM
If i do make my way back to 173 ill see what I can do, no promiseslooks fantastic anyway we can get this for a gb stock?
Uploading theme with some minor edits along with black/gray razr animation.
15.8KB 22 downloads
Posted 18 April 2012 - 01:19 PM
Sent from my DROID RAZR using Tapatalk 2 Beta-5
Posted 18 April 2012 - 01:32 PM
Besides ppl like to use third party launchers and use other icons, my theme just serves as the base or background for some. I'm sure someone will make another dark theme somewhere down the line, this is just the beginning of Moto ICS.
Posted 18 April 2012 - 02:16 PM
Posted 18 April 2012 - 08:46 PM
#17 Guest_BDH_*
Posted 18 April 2012 - 08:53 PM
Yo wulf is there a link for the new updated theme?
The link in his OP is the updated theme. Has a bigger file size than the previous theme.
Posted 18 April 2012 - 08:54 PM
#19 Guest_BDH_*
Posted 18 April 2012 - 08:58 PM
Kool ty spc
Not a problem!
Posted 19 April 2012 - 04:29 PM
