How To Repair Ics Leak If You Tried To Rsd And Failed
#21
Posted 27 April 2012 - 07:08 PM
#22
Posted 27 April 2012 - 07:09 PM
#23
Posted 27 April 2012 - 07:12 PM
#24
Posted 27 April 2012 - 07:19 PM
#25
Posted 27 April 2012 - 07:20 PM
#26
Posted 27 April 2012 - 07:28 PM
its is adb commands
Technically they're moto-fastboot commands
#27
And do I need DSK or anything special to run them?
#28
Posted 27 April 2012 - 07:32 PM
If your phone was properly detected in the past by rsd you should be fine.
#29
Posted 27 April 2012 - 07:38 PM
#30
Posted 27 April 2012 - 07:43 PM
I keep getting an error when I try to flash cdt.bin_16G. It says "unknown partition" and "cannot determine image filename for cdt.bin_16G" HELP!!!!!!!!!!!!
moto-fastboot flash cdt.bin cdt.bin_16G
#31
Posted 27 April 2012 - 07:47 PM
THANKS SOOOOOOO MUCH. BTW, there is a new update out that is now .85 not .84 on rombot. IDK if anyone has tested this but it is on rombot so I hope DH or DT tried it.
EDIT: The file is only 223MB....IDK what MOTO did but it looks like they effd up.
#32
Posted 27 April 2012 - 07:52 PM
Please don't install it til we get a bunch of testers on it.
#33
Posted 27 April 2012 - 07:53 PM
#34
Posted 27 April 2012 - 07:59 PM
thats my feeling atleast.. all of the commands cleared btw.
#35
Posted 27 April 2012 - 08:18 PM
Is it possible to make images from someone thats up and running? I think the problem I'm running into is that I attempted a revert on matts tool.. that failed on cdt.bin but continued on others... so even if the corrected cdt.bin for .84 is flashed... there are inconsistencies... which leads to the boot logo to black screen..
This would be correct. And matt has images. But they're for .85 so we'll have to see if this works first then proceed. I'll update the OP to reflect that this will only work for people who used RSD.
- MartyChubbs likes this
#36
Posted 27 April 2012 - 08:20 PM
I used RSD Lite 5.7 and I still failed. I am back on .84 though because of the fix. Maybe we should try flashing via moto-fastboot and do all files except cdt.bin and THEN try it via RSD. Idk just another theory.
#37
Posted 27 April 2012 - 08:21 PM
And I take it you're back up and running?
And yes I am. Thanks a lot you are a life saver.
EDIT: BTW I still have to use BP Tools to boot up. And I used RSD
#38
Posted 27 April 2012 - 08:26 PM
Same. But it makes the phone functional and thank you for the confirmation.
#39
Posted 27 April 2012 - 08:27 PM
cdt is a mapping file... pretty sure that's going to fail regardless. You're welcome to try though
#40
Posted 27 April 2012 - 09:14 PM
Sooooo... Do you want me to try it out for science? Sounds like I can at least get back on the leak.
If you don't think it's a good idea to even try I won't... Cheers
Sent from where I sent it from......
