Ics Leak. 84 Problems.(Not Fastboot)
Posted 28 April 2012 - 06:16 PM
1. I can be on charge and it say 60 r 70% unplug re plug and show 100% not charging. (Only noticed when off)
2 every time i reboot i dont launch on home screen, its one slide to the left? Every single time. Mind you this is with spb shell, not sure if its a leek prob, or compatibility prob.
I didnt have either of these on last ICS leak.
I am stock rooted, 10 % circle battery mod, and spb shell launcher.
Other than this things are great! Lovin this leak!
So what have you noticed?
Posted 28 April 2012 - 06:32 PM
Posted 28 April 2012 - 06:36 PM
Yeah man, spb is all good with 173 and 181, for me...So being your on ICS leak, idk? Hope this helps somehow? I know this is a thread started about new leak and all...I'm not running this leak, but I did notice spb shell 3d was doing the same exact thing to me on stock .748 stock .173 and eclipse as well... so maybe its an issue with spb shell...
Posted 29 April 2012 - 06:01 AM
I have spread my dreams beneath your feet. Tread softly because you tread on my dreams. -W.B. Yeats
Posted 29 April 2012 - 07:25 AM
I am fear my blade!
Posted 29 April 2012 - 07:36 AM
Posted 29 April 2012 - 07:48 AM
I am fear my blade!
Posted 29 April 2012 - 07:50 AM
I am fear my blade!
Posted 29 April 2012 - 08:12 AM
Im on the .84 leak and noticed my notification pull down works on the lock screen. It's never done that before on GB. I don't recall it doing that on the previous ICS leak?
The notification pulldown works as it is intended. This is a feature of ICS. It's on the Gnex and every build since the original ic3razr, including the previous leak. I asked about it too when i first noticed it but apparently it's part of the source code intentionally. Nothing to worry about
One thing I've been experiencing is a slow scroll every now and then. I believe it's related to cache management. That's the only major thing I've found so far. As soon ad the cache purges though it goes back to normal so it's no biggie really.
[ 43V3R IC3'd on .84 ]
Posted 29 April 2012 - 08:45 AM
.84 definitely had a problem with a compact resolution.
Posted 29 April 2012 - 09:15 AM
Posted 29 April 2012 - 11:15 AM
Posted 29 April 2012 - 11:29 AM
I am fear my blade!
#14 Guest_BDH_*
Posted 29 April 2012 - 12:08 PM
Some swipe games don't work right on .84..like temple run...
Temple Run works fine for me on .84
Posted 29 April 2012 - 12:13 PM
#16 Guest_BDH_*
Posted 29 April 2012 - 12:15 PM
The swipes get all mixed up...seems like scrolling also gets choppy in all apps.
Odd I haven't noticed any of that.
Posted 29 April 2012 - 12:26 PM
Posted 29 April 2012 - 12:52 PM
Posted 29 April 2012 - 01:27 PM
Posted 29 April 2012 - 01:43 PM
- DarkOverDroid likes this
