Ics Leak. 84 Problems.(Not Fastboot)
#21
Posted 29 April 2012 - 01:43 PM
I am fear my blade!
- ralphie0108 likes this
#22
Posted 29 April 2012 - 01:53 PM
I did a full on wipe after installing .84 and haven't found one single issue this far. I am very picky too.. Once I know an issue exists, it bugs the crap out of me till it's fixed. Not sure why I am like that but oh well lol
So no choppy scrolling? Do you think a wipe would fix that? I upgraded with all of my apps. I just happened to be on 173 stock so I just downloaded and flashed. Mine has been running flawlessly except for the choppy scrolling. And that's really only in tapatalk. But I use that quite a lot obv lol
[ 43V3R IC3'd on .84 ]
#23
Just curious, did you maintain root threw your wipe?
I am fear my blade!
If all he did was wipe data and cache then yes it shouldn't touch root
#24
Posted 29 April 2012 - 01:56 PM
I have choppy scrolling too...that and the swipe actions in tomb runner are my two big gripes. Battery life seems much worse than. 181 also...tomorrow will be a big test the last leak gave me wifi authentication issues at work, but 181 and below were fine.
#25
Posted 29 April 2012 - 02:11 PM
I am fear my blade!
Yep!! Although I believe I had to reinstall superuser from the market.
And make sure you haven't deleted or disabled the homescreen.apk from /system/app or you will be in lots of trouble.
#26
Posted 30 April 2012 - 04:48 AM
#27
Posted 30 April 2012 - 09:04 AM
Damn wifi sucks on this leak....constant authentication errors...I don't get it...gbread has always been fine and all my could workers can connect fine
I had that problem with the first leak because I installed without wiping first. A factory reset might help you if you have some non-ics compatible app instilled. I did a full wipe and do-over on the first leak but that not really an option right now. The only issue I've noticed is the shrunken home screen. I just installed trebuchet so that it would stop annoying me to look at.
#28
Posted 30 April 2012 - 10:28 AM
#29
Posted 30 April 2012 - 05:29 PM
Sent from my EPAD using Tapatalk 2
#30
Posted 30 April 2012 - 06:26 PM
Was on .85 but battery wasn't holding a charge. And I tried to boot a nadroid to .75 as I thought so I tried to RSS after the boot back to .75 and fail. Now if I reboot I go into the fast boot fail screen, how can I get to .84 or .85 again.
Go to this post, follow all instructions, and NEVER try anything untested like that, EVER. LOL
#31
Posted 30 April 2012 - 07:28 PM
Temple run is unusable because of swipe failing.
Battery life also is noticeably worse.
Freezes up a lot when lots of things are running, and chrome seems pretty slow.
But hey, I'm just glad I didnt brick it and that the leak is functional
#32
Posted 30 April 2012 - 07:57 PM
New to the forum here.. I too am on .84 [dumb idea]
Do a factory reset.. it helped mine become more responsive. Temple run is still screwed though
#33
Posted 01 May 2012 - 10:52 AM
#34
Posted 01 May 2012 - 12:45 PM
#35
Posted 01 May 2012 - 06:01 PM
#36
Posted 02 May 2012 - 12:28 AM
.84 build has been good to me...except the whole "hotel California" effect, of course
#37
Posted 02 May 2012 - 01:07 AM
so far the only issue I've seen is the wifi radio turning on automatically after I turn it off...the ghost in the machine, i guess.
That's a feature built in that can be turned off. Goto advanced settings in wifi.
#38
Posted 02 May 2012 - 01:38 AM
#39
Posted 02 May 2012 - 02:17 AM
I vote yes!
#40
Posted 02 May 2012 - 04:45 AM
Very niceI am liking the nickname "Hotel California" for this release... I think we ought to just start calling it that for both .84 and .85~
I vote yes!
I am fear my blade!
