//////// Disclaimer ////////
This is for people on the 84 leak ONLY. I take NO responsibility for what you do with these files. PLEASE be smart and only flash this if you already know how to recover from a softbrick on 84.
//////// warnings and notes ////////
- For this specific mod, you MUST be on the 84 leak. It has not been tested for anything but that.
- The 84 leak is the one that knocks you off of the official install path, so unless you're already on it, IGNORE THIS WHOLE THREAD!
- I would HIGHLY suggest installing the "CWM on boot" mod. This will be your tiny safety net incase something goes wrong. It can be found here:
- If you ignored the previous line....the 84 recovery method SHOULD save you, but this has NOT been verified.
Since these have become the norm recently, i'll include one as well.
Number of people who have publicly verified that this works: 4
//////// Installing //////////
- (optional) Do yourself a favor and install CWM on boot
- Download the deodex script
- (optional) Download the 1% mod
- Put both files onto your SD card
- Reboot into CWM
- (optional but recommended) make a backup!
- Install the deodex zip
- Reboot
- Upon restart, you should get a pop up with "Optimizing applications xxx out of 314" let that run
- (optional) Boot back into CWM and install the 1% battery mod then restart
- Enjoy!
- EmericanX for putting up with countless questions and providing the help i needed to finish this
- Deodex: (MD5: 5ffb02210290bc1f6c7457315bfe8dd1)
- 1% mod: (MD5: f77b0fe8a8daabdbd297bcb49d233e8a)
1% Mod:
//////// Potential issues ////////
- The gallery sync issue from the previous deodex MIGHT be present here, but I have not seen it yet. This still requires verification.
//////// Request ////////
If anyone can get me a /system pull of 85, I can try making one for that as well. PM me if you have one.
