hmm have you tried any after market apps? Other than I'm stumped. I myself haven't had any issuesI did a reflash with ought wiping still GPS ain't work I dunno what the deal is...
Posted 02 July 2013 - 11:56 AM
Posted 02 July 2013 - 02:21 PM
seems to be working now i dunno wtf after wipe and reflash so far no issues all my apps are all reinstalled and all my settings are back to the way it was... puzzling...
Posted 03 July 2013 - 09:14 PM
I tried installing a custom mms.apk, which but I get a FC message, which is weird beause it worked fine in Carbon, and it says it's compatible with AOKP.
Posted 04 July 2013 - 03:10 PM
Posted 04 July 2013 - 07:18 PM
Thanks for the update. Running fantastically so far. I was on the 6/30 build. So I decided to dirty flash the 7/3 build wait 5 minutes, then dirty flash the 7/4 build. Had no force close issues so far.
Posted 04 July 2013 - 07:55 PM
Posted 05 July 2013 - 12:29 PM
so far working good i tried the 7/3 update last night all i did was wipe and install then fell asleep when i woke up it was stuck in a boot loop it would turn black after the animation screen then restart... but the 7/4 build is working perfectly much better than the last build i had lots of problems with that build i never could get any kind of a reason for it just allot of randon stuff happened....
But Thanks keep up the hard work...
Posted 05 July 2013 - 12:32 PM
one thing thats been driving me nuts was the same on the last build also my lockcreen rotates even tho i do not have the lockscreen rotation active should look into it on ure next update....
Posted 06 July 2013 - 03:18 AM
Rom is sweet so far, running 7/4. One odd issue I noted was with bluetooth. I can pair with devices and make phone calls using it but when I attempt to do bluetooth audio streaming (using Gmusic), the phone locks up and has to reboot. Upon rebooting, it begins to bootloop. Had to do a restore to get it working again. Anyone else notice or have this issue?
Posted 06 July 2013 - 03:23 AM
Donations Not Necessary but tia
Posted 06 July 2013 - 03:30 AM
Yup, tried softboot and waited 10 minutes but was bootloopin. I also cleared dalvik and cache and tried to reboot with no luck. After doing a complete wipe and fresh install I attempted bluetooth audio streaming with the same results.
Posted 06 July 2013 - 05:20 AM
okYup, tried softboot and waited 10 minutes but was bootloopin. I also cleared dalvik and cache and tried to reboot with no luck. After doing a complete wipe and fresh install I attempted bluetooth audio streaming with the same results.
