op updated
(ROM) Unofficial Axi0m Port for Razr M 6/25/13
#122
Posted 19 July 2013 - 04:41 AM
I love everything about this ROM but when my hone attempts to auto connect to my car it reboots, and freezes at boot? any Ideas on how to fix this?
#123
Posted 19 July 2013 - 06:12 AM
- somber73 and droidrazrm like this
#124
Posted 19 July 2013 - 09:41 AM
2 questions, do you have to be on the 4.1.2. been holding off on the update, waiting for all the bugs to get sorted out. last question, is everyone installing with TWRP or can you use SS as well. thanks
#125
Posted 19 July 2013 - 09:48 AM
This is a 4.2.2 rom you don't get updates from Verizon and no you can't use this on ss you gotta be unlocked using TWRP or CWM
- somber73 likes this
#126
Posted 19 July 2013 - 10:51 AM
#127
Posted 19 July 2013 - 11:47 AM
fj? You prolly should get Matt's Utility for the xt907 and flash TWRP recovery(its the easier method) boot up in recovery wipe factory reset, and system back install the zip and the gapps that are in the opOK so what's the best course of action To install this rom. My phone is unlocked and running FJ 1.1
Donations Not Necessary but tia
#128
Posted 23 July 2013 - 03:22 PM
- brandon71 likes this
#129
Posted 23 July 2013 - 07:30 PM
Sent from my Droid RAZR M using Tapatalk 4 Beta
#130
Posted 24 July 2013 - 06:15 AM
Excellent ROM: one of the first I've seen (aside from stock, I guess) that runs smoothly on my phone; I've been using it so far for about 15 hours. :]
I notice one problem on my phone, not sure if it's a standard issue or specific to me, but whenever I plug in headphones or equivalent (e.g. car aux) and do anything with audio, everything appears to work fine.. aside from certain music players (Google Play Music, Fusion Music Player, but not Winamp) which leads me to believe there's an EQ problem. What happens with these problem players/EQ is that when I play music it only comes out of the right earphone or speaker. To reiterate, this does not happen on unequalized players or those that don't use system EQs, such as Winamp, nor on other sound-producing apps like youtube or the phone.
I'm not absolutely 100% that it's the EQ either (by the way this happens no matter which EQ I select, my current options being MusicFX, DSP Manager, and Fusion), but that's my best guess right now.
I'm still looking around for a solution but if anyone (or OP) knows what's up here, that'd be helpful :]
Thanks again for all the work on the awesome ROM!
#132
Posted 24 July 2013 - 05:02 PM
#133
Posted 24 July 2013 - 06:27 PM
hey guys both bawachale and i are having the same problem. any advice? google play music only plays out of one side of my car or earbuds.
#135
Posted 25 July 2013 - 04:34 AM
unfortunately its just one of those bugs some items never do go away. My only remedy for this was enter recovery wipe caches wipe data reboot recovery install ROM and gapps. Like tmstarting from a clean slate.I can't get rid of A flying jelly wallpaper file. does anyone know how I can delete it. Tried doing it through root browser & it won't go away, its like wallpaper herpes.
Sent from my Droid Razr M using Tapatalk 4 Beta
#136
Posted 25 July 2013 - 05:40 AM
boot into recovery and use TWRP file manager to delete the flying jelly folder, thats the only way it worked for me, it would not delete while phone was booted with any file manager
#137
Posted 25 July 2013 - 10:24 AM
THANK YOU, just the shot of penicillin it need.
#139
Posted 29 July 2013 - 03:25 AM
UPD. I see.. Sorry...
Is it possible to have GSM version of AXIOM?
And what about muntilang base?
Motorola Droid Razr M XT907 / ROM: KitStalk by GraberRoms
#140
Posted 30 July 2013 - 09:00 PM
