R3Ds Themes -=Ikandee-Urban-Ikream-Glassmix And Much More=-
#1 Guest_R3Ds_*
Posted 16 May 2012 - 09:05 PM
- mudthestud23, Gerland the Oracle and trikotret like this
#2 Guest_R3Ds_*
Posted 16 May 2012 - 09:24 PM
#3 Guest_BDH_*
Posted 16 May 2012 - 09:34 PM
HOLDING FOR LATER
Nice to see you on here!! I used your CM7 theme for God knows how long. Thanks for bringing your work to the RAZR as well. Can't wait to see what you can do when we get an official ICS upgrade. You're one of the themers that inspired me to do it. Thanks again!
#4 Guest_R3Ds_*
Posted 16 May 2012 - 10:02 PM
Thank you for your support, Im going to bring you guys some goodies.Nice to see you on here!! I used your CM7 theme for God knows how long. Thanks for bringing your work to the RAZR as well. Can't wait to see what you can do when we get an official ICS upgrade. You're one of the themers that inspired me to do it. Thanks again!
Posted 17 May 2012 - 06:27 AM
Posted 17 May 2012 - 06:29 AM
Is the battery info in your pull down part of this theme. If not where do you get it. It's sweet.HOLDING FOR LATER
Posted 17 May 2012 - 07:12 AM
Posted 17 May 2012 - 07:55 AM
Posted 17 May 2012 - 09:21 AM
#10 Guest_R3Ds_*
Posted 17 May 2012 - 09:30 AM
It works on bootstrap, I just never tested.So you can only use safestrap? Bootstrap will not work for this theme?
Posted 17 May 2012 - 10:26 AM
Posted 17 May 2012 - 10:57 AM
With the device in AP Fastboot recovery mode, you need to be attached to your cpu via USB.
Would the install work by rebooting into recovery with Razr Bootstrap?
tia, seeker
Posted 17 May 2012 - 11:29 AM
Posted 17 May 2012 - 11:33 AM
Posted 17 May 2012 - 11:36 AM
What other themes? I have flashed several themes and all have worked. Just make sure the theme is for eclipse. This theme is by far the best.anyone know if I can use the other themes as well?
Posted 17 May 2012 - 11:38 AM
I flashed via SafeStrap with no issues!It works on bootstrap, I just never tested.
#17 Guest_R3Ds_*
Posted 17 May 2012 - 11:39 AM
Bootstrap or safestrap.@R3Ds, love the look of your theme, & want to use it; but I'm not sure about your installation instructions.
tia, seeker
R3Ds Themes
#18 Guest_R3Ds_*
Posted 17 May 2012 - 11:42 AM
Urban for now, I will make more.What other themes? I have flashed several themes and all have worked. Just make sure the theme is for eclipse. This theme is by far the best.
R3Ds Themes
- bertovo5714 likes this
#20 Guest_R3Ds_*
Posted 17 May 2012 - 02:25 PM
tia, seeker
updated OP. i meant to say with safestrap, sorry for the confusion.
