Link should be working.Looking forward to flashing Urban 1.9 but looks like the link is down, is it being reworked/updated?
R3Ds Themes
Posted 01 June 2012 - 01:55 PM
Posted 01 June 2012 - 07:14 PM
R3Ds Themes
Posted 02 June 2012 - 04:21 AM
I'm updating to version 2.2 and adding to OP.Shows its not there....
Posted 02 June 2012 - 10:39 AM
Posted 02 June 2012 - 12:16 PM
Thanks, I have a rom for safeboot all stock blur and moto apps still there. Everything works and minor tweaks and mods. Any one want to test msg me.How you can make this any better than it already is, is beyond me. Great job my friend. She is my daily drive, look forward to more of your work :-)
Posted 02 June 2012 - 12:23 PM
Posted 02 June 2012 - 12:24 PM
Posted 02 June 2012 - 12:30 PM
Posted 02 June 2012 - 12:43 PM
Check pmLooks sweet. An ICS theme/Rom with R3Ds flair for stock .181. What could be better :-)
Posted 02 June 2012 - 12:56 PM
Posted 02 June 2012 - 10:48 PM
Posted 03 June 2012 - 07:07 AM
:@R3Ds
saw your post about ver 2.2 of your theme, so I went to the OP & didn't find the link to the new & I saw the instructions
for the current one & noticed that the instructions - which I am usually very careful to follow.
To my chagrin & surprise I noted that you said to use safe strap; & I used Razr Bootstrap.
I seem to recall that I had a frozen or looped boot after the post-install reboot. So I used the native reboot method of holding down power & volume down & rebooted.
Since I got it to start properly, I also changed back to the blue version of the stock razr theme.
I've had no probs - so is there any 'gotcha' that I should watch out for - after all - you said to use safestrap & I used boostrap.
tia seeker
Posted 03 June 2012 - 07:27 AM
Posted 03 June 2012 - 08:11 AM
Posted 03 June 2012 - 08:43 AM
Posted 03 June 2012 - 10:10 AM
Safestrap is the way to go for custom roms , is like dual boot from stock to custom rom. I only use safestrap with safe system enabled.No worries. I also used bootstrap to install the themes without issue. But after using safestrap, I don't think I'll ever use the other again. Makes it very east to switch between your stock, and custom Roms :-)
Posted 03 June 2012 - 11:57 AM
Posted 03 June 2012 - 12:56 PM
Any idea when the 181 themed version will be up and available?
