R3Ds Themes -=Ikandee-Urban-Ikream-Glassmix And Much More=-
#21
Posted 18 May 2012 - 01:06 AM
Lol welcome to the MAXX club man.
Going to flash eclipse just to flash this
be back with some love in the comments once done
#22
Posted 18 May 2012 - 01:42 PM
#23 Guest_R3Ds_*
Posted 18 May 2012 - 02:02 PM
What rom you on now , I can port it.very nice looking!!!! damn if I didn't just go to one of the other roms from the one this was built for. damn my luck.
R3Ds Themes
#24
Posted 18 May 2012 - 07:58 PM
R3Ds Themes
just this afternoon I decided to try the .79 ics leak.
I really like the trippy look of this theme. If I didn't have any manners, I would ask you to do something special like this for my new rom, but I probably won't stay on it long enough for it to matter enough for you to do it for me, as cool as it would be.
*edit-that all made sense when I thought I typed what I was thinking.
#25
Posted 19 May 2012 - 04:11 AM
#26 Guest_R3Ds_*
Posted 20 May 2012 - 06:39 PM
Go to play store and search batteryminder. They have free and pro.Is the battery info in your pull down part of this theme. If not where do you get it. It's sweet.
R3Ds Themes
#27 Guest_R3Ds_*
Posted 20 May 2012 - 06:40 PM
You welcome.I just want to say GREAT WORK, I REALLY LIKE THE LOOK OF THIS. I put it on last night and could not be happier!!! Thank you again for bringing it.
R3Ds Themes
#28 Guest_R3Ds_*
Posted 20 May 2012 - 09:28 PM
#29 Guest_R3Ds_*
Posted 20 May 2012 - 10:12 PM
#30
Posted 21 May 2012 - 03:48 AM
#31 Guest_R3Ds_*
Posted 21 May 2012 - 04:35 AM
im going to update the theme with more stuffI like the inverted notifications!!!! Glad you made that change, are you adding that as a update or is that a seperate file?
- Dabuck217 likes this
#32
Posted 21 May 2012 - 09:19 AM
#33
Posted 22 May 2012 - 05:47 PM
Sent from my DROID RAZR using Xparent Blue Tapatalk 2
- thisismalhotra likes this
#34 Guest_R3Ds_*
Posted 26 May 2012 - 11:37 AM
R3Ds Themes
#35 Guest_R3Ds_*
Posted 29 May 2012 - 12:47 PM
R3Ds Themes
#36
Posted 29 May 2012 - 05:17 PM
#37
Posted 29 May 2012 - 09:38 PM
just installed the 1.9 version of urban theme & I'm loving it a lot. The icons & color in the notificationin bar & Settings screen are gr8!
The colors & hilites of arrows for navigation & similar improvements make this theme rock!
I wiped cache & dalvik b4 installing the zip & was stuck in the post-reboot boot animation screen for a few minutes - so I concurrently pressed power button & volume down to reboot & this reboot finished in the normal time - approx 30-45 seconds or so (any correlation between pre-install wiping & elongated time for boot ani to finish?)
In the past I installed this theme & experienced low or no phone &/or data signal; which led me to restore my prev System files fm a recent nandroid backup.
This time I thought to check the settings for Data Network & found DN to be disabled.
Filling that checkbox & doing a reboot left me happily w/the DN setting persistent & phone & data signals performed better than ever…
Worthy of note, after this install "settled in"; I replaced the theme's boot ani w/the Blue Stock Razr boot ani… & re-installed my fave font (Comic, w/jrummy's Rom Toolbox Pro) & now I've been getting better performance than ever.
One observation, to add polish to a great job on this theme: when some screens pop up over others i.e. notification bar, it is a bit too transparent & the underlying screen is too visible - which is confusing & makes the popped up screen harder to easily read
b/c the screen underneath is distracting,
***EDIT*** the transparency occurred in 'edit / select' text popup, the rest is fine so far… just to clarify seeker
Otherwise, this Eclipse targeted theme is quite excellent.
Edited by seeker613, 30 May 2012 - 12:02 PM.
#38
Posted 30 May 2012 - 04:39 PM
just be sure that after going into ClockWork recovery that you wipe cache & then go into advanced section & wipe dalvik before flashing the theme.
good luck seeker
#39
Posted 30 May 2012 - 06:28 PM
Stock 181 based rom I'm making. With minor tweaks. Been testing Battery life and is solid on maxx 51hrs with 8% left.
R3Ds Themes
Release it already lol I love stock themed roms cause they are fully functional
#40
Posted 31 May 2012 - 08:14 PM
Urban theme Update version 1.9 with alot of changes
R3Ds Themes
Looking forward to flashing Urban 1.9 but looks like the link is down, is it being reworked/updated?
