Battery failing to charge
#21
Posted 13 August 2013 - 08:18 AM
#22
Posted 13 August 2013 - 08:22 AM
#23
Posted 13 August 2013 - 04:20 PM
If you can boot to safestrap, do so and then let it charge there. Charging is supported with safestrap 3+.
- cmh714 likes this
#24
Posted 13 August 2013 - 05:11 PM
Thanks for the advice.
#26
Posted 14 August 2013 - 03:46 AM
I've also found that not every wall charger works for the RAZR. I've tried using older cables for non-Smart phones and they don't work. I've also found those that do charge, but when you try to use the phone while charging, things act really weird, such as touching a particular spot on the phone doesn't register there but it registers elsewhere so the action you want to perform doesn't occur.
Glad you got it all worked out though. Hopefully it's not signs of the phone and/or battery going bad.
Sent from my Nexus 7 using Tapatalk 4
#27
Posted 18 August 2013 - 12:49 PM
Moving to Droid Razr General [XT912] - {Q&A, Discussion} - Reason Non-Emergency
