[Rom] Stealth Ics Cm9 6/12/12 [Any Leak]
36 replies to this topic
#1 2tealth
2tealth
    I Cannot Spell Stealth
  • 133 posts
Posted 09 June 2012 - 04:59 AM
Stealth ICS
Stealth ICS will be exclusive to droidrzr.com. Do not post the rom anywhere else, only link to this thread.
No longer developed, come to this Rom for more features and updates
Hi everyone, welcome to my first rom, Stealth ICS. Follow the instructions and enjoy.
So, what is this?
Stealth ICS is a rom based on dhacker's CM9 build. It contains lots of tweaks and changes that give you awesome speed and a great experience.
What are the tweaks?
Apex Launcher as default launcher
Apollo music
Custom wallpaper made by me (CM wallpapers --> first option)
CM9 wallpapers
Kernel logging disabled for speed
3g tweaks
Data on boot (buggy for some leaks if you touch the settings, waiting for dhacker to fix)
Hardware acceleration tweaks
Home launcher always in memory
Google Chrome and stock browser included
Jpeg quality optimized
Dalivk cache tweaks
Scrolling improvements
Custom boot animation
Support for sound during boot
See screenshots below for how wallpaper looks and a benchmark of my rom
How do I install this rom?
THE ONLY SUPPORTED METHOD OF INSTALLATION FOR THIS ROM IS SAFESTRAP.
PLEASE DO NOT REPORT BUGS IF YOU INSTALLED THIS WITH BOOTSTRAP.
1) Boot up into safestrap, make sure safe system is ON (safestrap menu --> toggle safe system)
2) Wipe data / factory reset option
3) Mounts and storage --> format system
4) Advanced options --> format dalvik
5) Install from sd card
6) Install Google Apps
7) ???
8) Profit
Download links
Known Issues
*On .79 leak in all roms home launcher lags. To fix simply change number of screens from 5 to 1 and enjoy
*Webtop
*If you get android system as a big battery drain, toggle airplane mode and wifi off and on as the rom is trying to toggle your data constantly. You can check if the issue continues by using adb logcat from your computer.
Screenshots
Spoiler
Testers
risenequinox
Changelog
6/12/12: Updated to dhacker's new build, camera is fixed.
6/11/12 5:40PM: Removed init.d tweaks, rom is very smooth now, version 1.3.1.
6/11/12: Updated to dhacker's new build, version 1.3:
Revert early implementation of MotoWrigley3G
6/10/12: Updated to dhacker's new build, init.d tweaks added, more data tweaks. Version 1.2
6/9/12 11:09 am: Updated to dhacker's 09 build, no change log from him yet. Bumped up version to 1.1 and upgraded apex launcher to 1.2.1. Also now you have a choice between Apex and Trebuchet.
6/9/12: First release
Drop a like if you enjoy this rom!
  • mugsy77, risenequinox, Muteki and 1 other like this
Founder and main developer of Team SpeedCore
#2 uberbdon
uberbdon
  • 367 posts
Posted 09 June 2012 - 05:01 AM
What sets this apart from KOA?
#3 2tealth
2tealth
  • 133 posts
Nothing, it's simply my own version of cm9.
#4 risenequinox
risenequinox
    Non Sub Bread
  • 33 posts
  • Twitter:_JMARvelous_
  • LocationOhio
  • Current Device(s):Galaxy S4
Posted 09 June 2012 - 05:21 AM
Downloading. don't mess up my stuff lol
#5 garywojdan81
garywojdan81
  • 633 posts
  • Twitter:gwojdan_81
Posted 09 June 2012 - 05:27 AM
Great contribution. Thanks for sharing your work.
#6 robthefive0
robthefive0
    Sarge
  • 315 posts
  • LocationN.J.
Posted 09 June 2012 - 05:44 AM
I'm trying it pal. I'll give you feedback ASAP.
#7 en7gm4
en7gm4
  • 137 posts
  • Twitter:https://twitter.com/#!/en7gm4
  • LocationtEXas
Posted 09 June 2012 - 06:00 AM
sweet the change log is a few months in the future. maybe this means the official ota came out on the 12 of june and this is based off of it.
#8 2tealth
2tealth
  • 133 posts
Posted 09 June 2012 - 06:08 AM
lol sorry totally messed up on that :D fixed now.
#9 claps1775
claps1775
  • 596 posts
Posted 09 June 2012 - 06:41 AM
So would it be best to fastboot back to .181 to install this? I have bootstrap installed right now. How is the 3g/4g toggle? The .79 at times cut in and out if you toggle. Then you have to restart phone to get a good data connection. I have them downloaded for for collection though.
Thank you.
#10 2tealth
2tealth
  • 133 posts
Posted 09 June 2012 - 06:47 AM
Thank you.
You can remove bootstrap by going into /system/bin and doing this:
delete hijack
delete logwrapper
rename logwrapper.bin to logwrapper
From there you can install safestrap and this rom. Data should be the same on this rom as it is on dhacker's cm9.
#11 tucstwo
  • Google+:tucstwo@gmail.com
Posted 09 June 2012 - 08:07 AM
Guess I give it a go. Curious to see how data is on this one.
#12 2tealth
2tealth
  • 133 posts
Posted 09 June 2012 - 08:10 AM
Get the build I just posted.
#13 bishaarcc
bishaarcc
  • 19 posts
Posted 09 June 2012 - 08:27 AM
I'm gonna try it nooooooooooooooooooooow..... and I will report it back to you guys.... thanks to dev........ I already think that I'm gonna loose the data but let me try it lol....
#14 tucstwo
Posted 09 June 2012 - 08:45 AM
Did you just update it?
...oh yes you did. Good thing I didn't flash it yet. We got a 1.1 only 4 hours later. What was changed between 1.1 and 1.0? What is different between your rom and dhackers CM9?
Edited by tucstwo, 09 June 2012 - 08:47 AM.
#15 2tealth
2tealth
  • 133 posts
Posted 09 June 2012 - 09:06 AM
Look at the features that are in mine... and changelog is at the bottom... read the thread lol.
#16 bishaarcc
bishaarcc
  • 19 posts
Posted 09 June 2012 - 09:08 AM
I did install it and yes, it has the data problem, the data is on boot, but after few minutes I get the problem so, it's amazing rom I like it but still there's the data issue on it, and that's all ics roms, lol
#17 risenequinox
risenequinox
    Non Sub Bread
  • 33 posts
  • LocationOhio
Posted 09 June 2012 - 09:58 AM
Yep no 4G for me. Still. Lol
#18 tucstwo
Posted 09 June 2012 - 10:03 AM
I didn't see the change log when I d/l the 1.1 version, perhaps you hadn't added it yet. Anyway, when I booted up mine phone was already set to GSM, so I toggled it to LTE and it seems to be working thusfar. Guess I'll give it some time to see how it runs. Much appreciated. The only thing that's kept me off of some of these roms is because none of them have had the same data stability as stock. But if I can find a nice stable one I will stick to it. I hope yours is it!
#19 tucstwo
Posted 09 June 2012 - 10:07 AM
Other than stock .209. I have no issues with .209. I live in an area where the 3g/4g flip flop based on what side of the street I'm on. It's craziness, but my phone always has a data connection. It's always seamless going from WiFi to 3G to 4G and back again. But you are correct, I can't seem to get a rom based on the ICS leaks to get data working properly and I always end up back on good old Motoblur.
  • jb_alphamale and 6flip9 like this
#20 2tealth
2tealth
  • 133 posts
Posted 09 June 2012 - 10:13 AM
Tusctwo the change log is at the bottom of my post.
