I know, I see it there now, but it wasn't there when I d/l 1.1 a few hours ago, that's what I'm saying. Never mind...makes no difference because dhackers source change log hasn't updated.Tusctwo the change log is at the bottom of my post.
[Rom] Stealth Ics Cm9 6/12/12 [Any Leak]
#21
Posted 09 June 2012 - 10:35 AM
#22
Posted 09 June 2012 - 10:39 AM
I have no idea why is that but for me this is the only ICS leak custom ROM that brings data on boot. It's been more than 24 h now since I put it on and traveled and turned on/off the phone multiple times. Data comes back right on. It takes about 2-3 min to get active but I don't have to toggle. It sets itself on LTE/GSM/CDMA auto (PRL). I'm in roaming 3G area.
The ROM it's stable and did not have any FC. I like the boot image.
There is no way to add or change the power toggles though.
I'm happy with it.
Thanks 2tealth.Good work and keep it up with updates.
Other than stock .209. I have no issues with .209. I live in an area where the 3g/4g flip flop based on what side of the street I'm on. It's craziness, but my phone always has a data connection. It's always seamless going from WiFi to 3G to 4G and back again. But you are correct, I can't seem to get a rom based on the ICS leaks to get data working properly and I always end up back on good old Motoblur.
#23
Posted 10 June 2012 - 06:58 AM
So i'm running this rom for about a day, and I didn't ger any single problem, data good, everything works, Please remember, if you are on 75 ics leak, you will get data issue, you have to be on 79 leak or later... thanksI did install it and yes, it has the data problem, the data is on boot, but after few minutes I get the problem so, it's amazing rom I like it but still there's the data issue on it, and that's all ics roms, lol
#24
Posted 10 June 2012 - 07:38 AM
I am on .209 with very bad data issues so I doubt it has anything to do with any single rom
#25
Posted 10 June 2012 - 11:44 AM
uh...thats wrong
#26
Posted 10 June 2012 - 04:01 PM
I ran version 1.1 for a day and also had big problems with data, also on .209. Id may give this another chance after its tested by the users for a whole. I will say it ran beautifully otherwise.
#27
Posted 10 June 2012 - 04:30 PM
#28
Posted 10 June 2012 - 07:54 PM
- bishaarcc likes this
Founder and main developer of Team SpeedCore
#29
Posted 10 June 2012 - 08:32 PM
hey 2tealth' i was running ur rom about 2 days and never had data issue or any problem.If you are getting data issues read the known issues section, nothing I can do about it until dhacker patches it in a new build.
#30
Posted 11 June 2012 - 05:23 AM
Yea, the issues start only once you start messing with data settings.hey 2tealth' i was running ur rom about 2 days and never had data issue or any problem.
#31
Posted 11 June 2012 - 02:48 PM
#32
Posted 11 June 2012 - 07:23 PM
#33
Posted 11 June 2012 - 08:35 PM
#34
Posted 12 June 2012 - 06:00 AM
It does, but it is not the supported method. If you brick during bootstrap installation you'll have to fastboot back, but with safestrap you just reflash it.When will aokp/cm9 support bootstrap?
#35
Posted 12 June 2012 - 06:46 AM
Edit: Fixed in 1.4
#36
Posted 12 June 2012 - 02:14 PM
well i flashed it in bootstrap to test and it booted fine but camera does not work for me and i lost data upon boot. i know it isn't a supported method but i still don't see a reason why the devs are against bootstrap? you just install cwm on boot and your good to go, you can restore a nandroid in case you go into a bootloop or whatever. guess im stuck on stock for now.
i do have a question though about the data on the roms. do you think once we get the offcial ics the data drops will go away?
#37
Posted 12 June 2012 - 02:38 PM
If you brick the part of the system that will load bootstrap on boot then obviously you cant restore a nandroid. Also camera was fixed in version 1.4. Data will not be stable until official O ta because there are at least 6 leak versions and making data work for each one all at the same time just isn't going to happen. Yes it will be fixed when it comes.well i flashed it in bootstrap to test and it booted fine but camera does not work for me and i lost data upon boot. i know it isn't a supported method but i still don't see a reason why the devs are against bootstrap? you just install cwm on boot and your good to go, you can restore a nandroid in case you go into a bootloop or whatever. guess im stuck on stock for now.
