Well i got a Droid Razr M for an upgrade, It worked great so i rooted it, Still worked great. Next morning i woke and my phone would connect to the WiFi... It wouldn't even let me enable the WiFi! The toggle switch in a darker gray than the others. I unrooted it, Soft & Hard reset it but still nothing! I have done all i could think of.
Posted 27 August 2013 - 03:22 PM
Posted 28 August 2013 - 05:28 AM
So... no one can help me?
Posted 28 August 2013 - 05:33 AM
I assume you have done the basic stuff... reboots of phone and router??
You can use
utility to return to out of the box stock. That should get you fixed up.
Posted 28 August 2013 - 07:39 AM
Posted 28 August 2013 - 09:04 AM
What if you actually go into settings? Is the Wi-Fi greyed out there as well
Yes, It was working fine!? I went to sleep then it was not working when i awoke! I really hope its not hardware...
Posted 28 August 2013 - 11:18 AM
XT912 RaZR SpYdEr CDMA
hit ThAnKs if I was helpful!!!
Posted 28 August 2013 - 11:55 AM
Or simply do factory reset if not already..
I have done this so many times i have lost count.
Posted 28 August 2013 - 12:04 PM
Running the full Utility will flash stuff a factory reset doesn't touch
Posted 28 August 2013 - 12:50 PM
Its still doing it. I guess the only other possibility is that its hardware...
Posted 30 August 2013 - 02:50 AM
is this only occurring on your home wifi router? could be your router.... try at a different location. also, make sure to uncheck "avoid poor network connections" and "keep wifi on during sleep" is set to "always".
you might also want to check your networks to see if there is one that has a higher priority that is preventing your phone from connecting to your home router.
I know you said that you did a hard reset, but are there any apps that you installed recently?
ROM: OSE KitKat 4.4.2
Posted 30 August 2013 - 04:33 AM
I would venture a guess and say hardware.... since hard reboot, factory data reset, and the utility have all been tried.....
"... try not, do! or do not! there is no try..."
Posted 30 August 2013 - 06:31 AM
sorry bud!I have done this so many times i have lost count.
Posted 02 September 2013 - 10:32 AM
I assume you have done the basic stuff... reboots of phon78and router??
You can use
I am now confused. The target of your reply is on ...78 right? Matt states 1.20 is not updated for ...78 or so i thought.
It has notice on his xda op.
Also tagged with one or more of these keywords: WiFi, Hate, poop, hate, this
