I got a Droid Razr M for an upgrade, Worked great so i rooted it, Still worked great all that day, then i went to sleep and when i woke and the WiFi would not work!
The toggle switch turned a darker gray, When i tap it it turns on then in a split second turns back off.
I have done a Factory Data Reset and then i did a hard reset and then i wiped the hole thing out and re flashed it to its original state. Still would not work!
So as a last resort contact Motorola for support and they tell me that i had rooted my device and there is nothing they can do. I didn't say anything about rooting it so they must be logging all users data. (Invasion of Privacy?)
So i am back here again, Not being able to use WiFi, On a 2GB/M plan. f%$king peace of $#!+.
Nothing else is bad! Its just the wifi!?
