Best Answer cmh714 , 02 September 2013 - 03:02 PM
You can try and wipe cache and dalvik or you will need to use Matts utility: http://www.droidrzr....nux-all-in-one/
try holding the vol down button and then power, when the screen flickers, let go of power and that should put you into fastboot mode.
You can then hit power to power off, or use Matts utility and start over
Go to the full post
