Difference Between Black Widow Rom And Ics Leaks
Posted 17 June 2012 - 10:14 PM
Sent from my DROID SPYDER using Xparent ICS Tapatalk 2
Posted 18 June 2012 - 01:54 AM
#3 Guest_R3Ds_*
Posted 18 June 2012 - 05:02 AM
R3Ds Themes
#4 Guest_R3Ds_*
Posted 18 June 2012 - 05:04 AM
R3Ds Themes
Posted 18 June 2012 - 09:31 AM
Posted 18 June 2012 - 10:30 AM
Black Widow is very stable running the .79 leak, and just about everything is fully working ( - Webtop ). ...... couldnt be much happier, and being able to fastboot back for whenever the OTA actually happens.... but having the video recorder, chrome beta and 4g data on boot is definitely a Plus coming from a gb-ics ROM. needless to say, its worth it in every way, specially seeing how easy it is to upgrade and go back if/when needed.
Agreed..... i'm still on the 79 leak as well and have to say BW for ICS runs ROCK SOLID without issue. Everything works except for the few things we all know about. And to date since flashing it agian I've yet to have a data drop on it. Swithces between LTE & 3g no problem what so ever.
Posted 18 June 2012 - 10:46 AM
Posted 18 June 2012 - 11:55 AM
I have had so few problems with the gb ics bw I am gonna follow the instructions to get on the leak. I'll post again when I'm done. Thanks again andlaw.
sounds good man!! follow the directions to the T, and you shouldn't have any problems, and if you do, don't hesitate to ask. ..
Posted 18 June 2012 - 12:02 PM
Posted 18 June 2012 - 12:14 PM
