Best Answer lowvolt , 24 October 2013 - 08:44 PM
I think he tried 1.3 and it didn't work.
Sent from my XT1060 using Tapatalk
Go to the full post
Go to the full post
Posted 23 October 2013 - 09:52 AM
Posted 23 October 2013 - 01:15 PM
Posted 23 October 2013 - 03:25 PM
Sig by
Posted 23 October 2013 - 04:27 PM
Posted 23 October 2013 - 05:00 PM
This one that you posted?
No use
Utility. You can root and also unlock your bootloader
Posted 23 October 2013 - 05:05 PM
If you are on 98-16-3 then use the original moto chopper for root and unlock that thing with motopocalypse before you update! Then root will never be an issue. Sent From My DEV X
I thought .3 and .78 were the same update but with a different version #? If that's the case, he'll need to use your Motochopper 1.3.
Posted 23 October 2013 - 05:10 PM
Posted 23 October 2013 - 05:11 PM
No it's the .16 which goes to .18 or .20(which are the same). The .16 is still before the update that killed the BL unlock
Posted 23 October 2013 - 05:39 PM
Alright, but I could've sworn I've seen people try to unlock .3 and it failed for the same reason as .78. I thought I saw somewhere that they were the same updates but the version number was different depending on whether or not people took the previous soak vs. the actual OTA. I might be getting versions mixed up, though.
Posted 23 October 2013 - 05:42 PM
Yeah those people had already updated and tried to flash back and unlock. You are right about the 2 versions but it was .16 ->.19 -> .20(soak or MR4) and .16 -> .18 OTA/MR2
Posted 23 October 2013 - 05:46 PM
Posted 23 October 2013 - 05:49 PM
So use the one posted by memnoch?
Yes sir.
Posted 23 October 2013 - 06:27 PM
Posted 23 October 2013 - 06:29 PM
Sig by
Posted 23 October 2013 - 06:47 PM
Posted 23 October 2013 - 06:49 PM
I didn't think the whole BL thing was an option anymore? Or is it still an option for my version?
As long as you have never taken the OTA up to .18 or .20 then your version .16 "should" unlock...
Posted 23 October 2013 - 06:52 PM
Posted 23 October 2013 - 07:10 PM
Ah, gotcha. Makes sense now.
Posted 23 October 2013 - 07:24 PM
Posted 23 October 2013 - 07:25 PM
