[Energy ROM] Camera issues
#21
Posted 27 October 2013 - 03:44 PM
Omg is there like a list that shows roms I can use on my RAZR M without being unlocked??? Its really difficult to find any that my device can support.
#22
Posted 27 October 2013 - 03:52 PM
Sent from my XT1060 using Tapatalk
#23
Posted 27 October 2013 - 03:58 PM
Ok ill check it out again lol that sucks xD
#24
Posted 27 October 2013 - 04:00 PM
You think you could help me find a version of Eclpise that will run on my phone without bootloader being unlocked? I wanted to use Eclipse but I cant find the one for mine. As long as it is jelly bean I can use it right??
#25
Posted 27 October 2013 - 04:01 PM
Everytime I go to the link on a site it just sends me to elemental x.com and Idk where to find it.
#26
Posted 27 October 2013 - 04:04 PM
#27
Posted 27 October 2013 - 04:05 PM
Ok I found Eclipse v1.2 for the RAZR M do I need the gapps file though because it wasnt there with the instructions the only download was the rom itself
#28
Posted 27 October 2013 - 04:35 PM Best Answer
Ok kool it worked!
#29
Posted 27 October 2013 - 04:40 PM
Even if you flash Eclipse, you'll still have problems with the camera. It's because you have the newer kernel. The camera issues come from trying to run two different kernels. You'll get the same if you happen to find the older CM10 for SS. I ran CM10 for about a month on SS and never had a working camera and WiFi wouldn't connect if I was more than 20 feet from router. All of that was kernel issues. If I needed a camera, I would just boot back into my stock slot and use my camera.
Elemental X is Nitro's website. The older Eclipse is in the Razr M subforum.
#30
Posted 27 October 2013 - 05:48 PM
Guess I never thought of it that way lol I just take a lot of pictures.
