Stuck in AP Fastboot
#101
Posted 03 August 2014 - 02:13 PM
#102
Posted 03 August 2014 - 02:16 PM
And how are you flashing it?
#103
Posted 03 August 2014 - 02:26 PM
#104
Posted 03 August 2014 - 02:28 PM
sent from my G3
Sig by
#105
Posted 03 August 2014 - 02:42 PM
And what's the status of the battery?
#106
Posted 03 August 2014 - 03:22 PM
#107
Posted 03 August 2014 - 04:48 PM
#108
#109
Posted 03 August 2014 - 05:34 PM
I really don't know what to tell you. Getting information from you has been a very difficult process at best. I have patience when trying to help people but they aren't unlimited. The simple facts are this.
o) If you were on a 4.4.2 build, you must use the same 4.4.2 FXZ...or higher. But if you were on the soak build 4.4.2, then there is no FXZ and you're SOL for several weeks until one appears...
o) You *should* know if you're on the soak build as you'd either have to be in the soak test or manually flash it from the download thread on this or other forums to install it.
o) If your version matches the 4.4.2 build, and you're still getting errors, we're going to need a hell of a lot more information than the ridiculous amounts of nothing you've provided so far. SWDL.txt file, exact text of the AP Fastboot on your phone, the exact version of RSD Lite you're using, the version of windows you're using, what moto USB driver you're using, whether you'e using a USB 2 or USB 3 port, whether you're using the OEM cable that came with the phone, etc.
This isn't something we should have to ask for. This is stuff you should be providing to us so we can help you. Having to pull information out of people is just demotivating when trying to help someone.
#110
Posted 04 August 2014 - 02:10 PM
Im running vesion 6.1.6. of rsd. My fastboot screen says:
AP Fastboot Mode (S)
10.9B(*) (sha-1e9f557, 2013-09-26 12:31:42)
eMMC Info: Size 16GB
Device is UNLOCKD, Status Code 3
Battery OK
Connect USB
Data Cable
Fastboot Reason: Sticky bit factory_fastboot
It does not have its original oem cable I bought the phone off of graigslist.
#111
Posted 04 August 2014 - 02:27 PM
- RikRong likes this
#112
Posted 04 August 2014 - 03:06 PM
Thank you IM out of that loop ,
but now all I get is the red Motorola logo for a min or two then then fades out that's it. So is it possible
to flash new firmware and start fresh?
#113
Posted 04 August 2014 - 03:24 PM
"new firmware"....no, you can try flashing the SAME firmware again.
#114
Posted 04 August 2014 - 05:33 PM
Im still trying to learn but the only file I can find is xml.not a zip and rsd flasher doesn't even seem to respond unless its a zip .
