If you're familiar with the HoB then the HoM will feel right at home and more powerful. Follow the install instructions carefully to avoid common mistakes and you should be good to go.
Stuck in AP Fastboot
#81
Posted 25 June 2014 - 04:46 PM
#82
Posted 25 June 2014 - 05:01 PM
I haven't played with my RAZR in a long time. Splitting time between a unlocked BL Note 2 and a BB Z30.
I'm selling the RAZR to a friend who has no interest in anything other than stock. I hate selling the unlocked phone, but I no longer use it.
#83
Posted 25 June 2014 - 05:30 PM
It's all good. The HoM will fix her right up.
#84
Posted 03 August 2014 - 08:17 AM
I have a Razr HD XT926 was running kitkat 4.4.2. Was Rooted and unlocked..Was trying to install a custom recovery...Got stuck in a bootloop just seeing the red moto logo. Ive been trying to flash back but get a fail somewhere in the flash process. But now it stays in fastboot mode ...Flash failure.. What do I do?
#85
Posted 03 August 2014 - 08:25 AM
"But get a fail somewhere in the flash process."
I suggest you turn that fail into a success. Not really enough information on how to do that? I would agree.
#86
Posted 03 August 2014 - 10:12 AM
Lol I see. Well on my phone it says: flash failure usb connected invalide image size for partition tz . On rsd it says failed flashing rocess."1/23 flash sbl1.mbn"
#87
Posted 03 August 2014 - 10:15 AM
It means whatever FXZ you're flashing is wrong.
#88
Posted 03 August 2014 - 10:26 AM
I thought so .Im just downloading all the Motorola firm ware downloads and trying each one ...No luck yet
#89
Posted 03 August 2014 - 10:30 AM
Um, wow. I don't even know what to say to that. Just randomly flashing things to your phone? And you wonder how you got bricked? If you were on 4.4.2, then it should be very clear that you need the 4.4.2 FXZ.
- RikRong and bigrome like this
#90
Posted 03 August 2014 - 10:46 AM
I know your right but I tried that and I removed the getvar line and nothing.
#91
Posted 03 August 2014 - 10:59 AM
"nothing".....like the amount of information that is useful in helping diagnose the problem. :
#92
Posted 03 August 2014 - 12:16 PM
so does that mean Im done for? It fails at gpt.bin this is a annoying.
#93
Posted 03 August 2014 - 12:22 PM
youre not done....you need the latest FXZ for your phone and one of Sams tools and then read and follow instructions and you should be fine.
- johnthehillbilly likes this
#94
Posted 03 August 2014 - 01:12 PM
Sent from my XT1053 using Tapatalk
#95
Posted 03 August 2014 - 01:32 PM
#96
Posted 03 August 2014 - 01:39 PM
#97
Depends on whether you installed the soak build or not.
#98
Posted 03 August 2014 - 01:43 PM
#99
Posted 03 August 2014 - 01:53 PM
In your current bricked state? You don't. What is the EXACT filename of the FXZ you downloaded and are trying to flash?
#100
Posted 03 August 2014 - 02:12 PM
