Give Blurry 2.2 a try if you want a blur based Rom. That and Aviator are still getting updated. Cm 11 runs ok. The only major problem is the camera on the latest nightlies. This can be overcome by pulling the camera from the 12/22 nightly and installing it on the latest, or by using Camera Zoom FX from the playstore. Battery on the CM nightlies is quite good now, almost on a par with the blur roms. I use hotplug as my governor, and deadline as my scheduler on CM and Aviator. On blurry I use the default governor and deadline. Seems to give the best battery for me.
Thanks. When u mention camera issue, is it on the Aviator or the Blurry gummy Rom, or both CM having issue, too? I am getting confused with mention of these Choices:-) Would just like the most stable of each of them. I had been using CM 10.2 abd it is a bit buggy. Not to happy with it. As a matter of fact, it is still in Slot 1 on my xt912. Switched to old Nexus to try KitKat, and it's a bit buggy too. So, now decided to give xt912 another go using their Kitkat.:-)
