Overclocking Ics For Dummys
#141
Posted 27 July 2012 - 09:12 AM
#142
Posted 28 July 2012 - 03:03 AM
#143
Posted 28 July 2012 - 10:22 AM
#144
Posted 28 July 2012 - 10:49 AM
- studiorat likes this
#145
Posted 28 July 2012 - 11:54 AM
#146
Posted 28 July 2012 - 02:42 PM
Where can this be found at? Is the OP still current?You shouldnt use that, just use the cpu manager module
removed
#147
Posted 28 July 2012 - 06:20 PM
really...I used this method exactly!!! and Bricked...... i uninstalled CWM and all is fine...CWM is not compatible with my maxxNo have to uninstall safe strap and use the cwm recovery I gave you
Sent from my DROID RAZR MAXX Overclocked using Tapatalk 2
care to elaborate as to why you must use CWM
- ralphie0108 likes this
#148
Posted 28 July 2012 - 07:00 PM
#149
Posted 28 July 2012 - 07:56 PM
An update is available
LINK IS DEAD!!!!
Edited by spc_hicks09, 28 July 2012 - 08:19 PM.
#150
Posted 29 July 2012 - 06:26 PM
#151
Posted 29 July 2012 - 06:28 PM
#152
Posted 29 July 2012 - 08:32 PM
script to copy, paste and run (exactly as is):
#!/system/bin/sh
insmod/system/lib/modules/symsearch.ko
insmod /system/lib/modules/cpu_control.ko
echo 0 300 1025 > /proc/cpu_control/tweak_cpu
echo 1 500 1195 > /proc/cpu_control/tweak_cpu
echo 2 750 1320 > /proc/cpu_control/tweak_cpu
echo 3 1000 1388 > /proc/cpu_control/tweak_cpu
echo 4 1325 1400 > /proc/cpu_control/tweak_cpu
#153
Posted 30 July 2012 - 06:35 AM
careful, no space on first line between insmod and /system
#154
Posted 30 July 2012 - 08:20 AM
#155
Posted 31 July 2012 - 07:16 AM
#156
Posted 31 July 2012 - 11:24 PM
#157
Posted 02 August 2012 - 10:08 AM
After a few migraines trying to read different forums at XDA, I've finally put together a simple way to overclock my RAZR. Just flash the two zip files (wipe cache and Dalvik) from the below link (I'd upload the files here, but they are over 500k together) in recovery than run the below script and you are overclocked. I am currently on .215 running the axiobeam ROM and using SETCPU I'm at 1325. My quadrant score increased almost 500 points. I have not tried any other leaks nor have I played with VSeLs, but wanted to share what I have with you all:
#!/system/bin/sh
Just ran this script successfully and am happy with the results. I OC'ed to 1325, but even with the flashed 0.1.3 kernel modules and init.d .zip files, I am not seeing the Kernel Modules, only the 5 I usually see. (Where is smartassv2, pegasusq, boostedass, etc.?)
#158
Posted 02 August 2012 - 11:14 PM
- bradenfontaine likes this
#159
Posted 03 August 2012 - 06:10 AM
Edit: Nevermind i missed a step. Cheers!
Edited by bradenfontaine, 03 August 2012 - 06:42 AM.
#160
Posted 03 August 2012 - 09:59 AM
