My phone did this too until I changed setvsel to 53. In the o.p it says setvsel between 58-52 for stability. I'm getting over 7000 on antutu!My phone couldn't handle it either. I guess we have to keep waiting.
Sent from my .215 leak razr on arctic215 rom do you wanna get cut?
Overclocking Ics For Dummys
#101
Posted 25 July 2012 - 08:52 AM
#102
Posted 25 July 2012 - 08:56 AM
Sent from my Droid Razr using Tapatalk 2
#103
Posted 25 July 2012 - 08:57 AM
I downloaded setvsel and have'nt seen a place to change the values. Just the percentages for each vsel to take over at the bottom?? Also, where did you find a 1375 script? I'm trying to find a 1325 script as thats where my phone was stable before. Right now my speeds are all over the place aka no stability, so I need to figure out how to change the vsel or vesel whatever its called? lol
As of right now, we do not currently have available frequencies other then 1350mhz. This is very much a beta and a proof of concept but expect awesome results in the future.
#104
Sent from my DROID RAZR MAXX Overclocked using Tapatalk 2
#105
Posted 25 July 2012 - 09:00 AM
Duh! Thanks for the infoSetvesel
#106
Posted 25 July 2012 - 09:06 AM
I had mine set to 52 and I was still getting random reboots and heat issuses. Plus i'm not gonna worry about it because when the HTC phablet drops i'm switching
#107
Posted 25 July 2012 - 09:08 AM
Thanks for all your help by the way!Setvesel
#108
Posted 25 July 2012 - 09:12 AM
Every android phone I've had before this has been HTC! I like their phones but I'm getting used to a more stock experience. I am definitely interested in this phone/tablet you're talking about though! Verizon? Have any links for me to drool over?I had mine set to 52 and I was still getting random reboots and heat issuses. Plus i'm not gonna worry about it because when the HTC phablet drops i'm switching
#109
Posted 25 July 2012 - 09:16 AM
Heres the link [ ]
SORRY FOR GETTING OFF TOPIC GUYS
#110
I'm on Ikream btw. Not sure what rom you are using, but they say every phone is different, so I'm sure every rom is different too obviously.I had mine set to 52 and I was still getting random reboots and heat issuses. Plus i'm not gonna worry about it because when the HTC phablet drops i'm switching
#111
Posted 25 July 2012 - 09:32 AM
Sweetness! Thanks man. HTC has a crazy following from developers so I can only imagine the possibilities! I'll be jumping on that, even though it's ics. I've been an HTC fan since the Evo got me away from apple, but the razr has been good to me. Especially the battery since I have the MAXX. I'll probably keep it as a backup. But I'll shut my typing trap bc I could go on, but this isn't the thread for that.Heres the link [
I will say, the only thing I missed about my HTC 3d is overclocking and these guys scratched that itch! I always donate when developer comes up with something I specifically was hoping for. Anyways as he said, sorry for getting off topic guys!
- Nnnnr12 likes this
#112
Posted 25 July 2012 - 12:14 PM
#113
Posted 25 July 2012 - 01:56 PM
#114
Posted 25 July 2012 - 02:54 PM
#115 Guest_Bbyland_*
Posted 25 July 2012 - 04:29 PM
Flash-o-holic
#116
Posted 25 July 2012 - 04:44 PM
So I was able to run the script and everything seemed fine...Got an average of 6800 on antutu and 3400 on quadrant...The only problem is as soon as I turned my screen off, the cpu would go to 300/300 and not change until I went into SETcpu and clicked 1350 again....I mean it's not that big of a deal but is there anyway to fix this?
Use no frills cpu
#117
Posted 25 July 2012 - 04:45 PM
I found an issue with setvesel as well. Everything was stable for me at 1350 until I loaded that app & brought the threshold from 86 to 55. Everything began to lag and hang on opening or closing apps. It took an uninstall & cache/dalvik wipe to straighten it out.I found the problem of it resetting when I turned the screen off. It seems setvesel was the problem in resetting it, why? I do not know but I know once I uninstalled it that it now stays at 1350 even after a reboot. I just have to make sure this doesn't overheat.
#118
Posted 25 July 2012 - 04:49 PM
Day two stable as can be and still rockin
42.17KB 22 downloads
What are you using
#119
Posted 25 July 2012 - 04:52 PM
#120
Posted 25 July 2012 - 04:54 PM
