Red Widow Boot Animation
15 replies to this topic
#1 DSGMach1
DSGMach1
    Themer
  • 264 posts
  • LocationGriffin, GA
Posted 23 July 2012 - 10:18 PM
I made this boot animation to complement my Red Widow theme.
It is my first one and would not have been possible without the help of JaeKar99. Be sure to check out his boot animations.
Instructions:
1. Download theme here
or here
2. Move to sd card
3. Using ES File Explorer/root browser go to system > media > rename bootanimation.zip to bootanimation.zip.bak
4. Now using your file explorer go to the sd card you saved the new boot animation to and copy it to system > media
5. Set permissions to rw- r-- r--
6. Reboot
NOTE: Actual boot animation is smoother and faster than the gif below shows.
  • HSD-Pilot likes this
#2 andlaw
andlaw
    BW ftw!! !!!!!
  • 2,463 posts
  • LocationOH-I-O
Posted 23 July 2012 - 10:45 PM
Sweeeeeeeeeeeet! looks sick dude! great work!
#3 DSGMach1
DSGMach1
    Themer
  • 264 posts
Posted 23 July 2012 - 10:51 PM
Thanks. I'm looking forward to playing around and making another one. I'm not sure if it is my laptop, photobucket, or the forum, but one of them is butchering the gif compared to it on my computer or opened in its own tab.
#4 mattlgroff
mattlgroff
    The Dark Knight
  • 2,298 posts
Posted 23 July 2012 - 10:53 PM
Looks great, there is a few sites for making gifs and you get set the FPS to be the same as the boot animation. Wouldn't be a bad idea to go Google some more on em! Love the look/animation must have taken forever!
#5 DSGMach1
DSGMach1
    Themer
  • 264 posts
Posted 23 July 2012 - 10:58 PM
Really not as bad as you would think. I basically just made a video in Sony Vegas Pro then rendered as a image sequence. Only had to find which image needed to start the loop after that.
#6 JaeKar99
JaeKar99
  • 222 posts
  • Twitter:JaeKar99
  • LocationTwin Falls
Posted 24 July 2012 - 02:49 AM
Liking that! - Thanks for the props!
This IS my stress relief.
If you are feeling extra generous - I like coffee.
#7 dysfunkshun
dysfunkshun
  • 102 posts
  • LocationLas Vegas
Posted 24 July 2012 - 02:39 PM
Looks damn good, nice work!
#8 DSGMach1
DSGMach1
    Themer
  • 264 posts
Posted 25 July 2012 - 09:21 AM
Wrong thread.
#9 cavy737
cavy737
Posted 31 July 2012 - 10:42 AM
I cant seem to get it to work. i think im following the directions correctly. any help
#10 DSGMach1
DSGMach1
    Themer
  • 264 posts
Posted 31 July 2012 - 03:23 PM
Check the permissions on it. With root browser or es file explorer long press on it and make sure the permissions are set to rw- r-- r--
I'll load it back on to my phone tonight to make sure it works on mine with no problems.
#11 DSGMach1
DSGMach1
    Themer
  • 264 posts
Posted 02 August 2012 - 12:47 PM
working on this. Found a little problem last night. You need to set permissions on it to use it.
#12 DSGMach1
DSGMach1
    Themer
  • 264 posts
Posted 02 August 2012 - 09:20 PM
Updated the boot animation bc I found it wouldn't work correctly when I switched to BW AOKP rom.
#13 tjb51681
tjb51681
Posted 18 August 2012 - 12:44 AM
Cant seem to get it to work, it is set to rw- r-- r-- Any suggestions?
#14 Guest_BDH_*
Guest_BDH_*
Posted 18 August 2012 - 01:11 AM
Did you set permissions before or after you put it in /system/media ?
Sent from my ADR6425LVW using Tapatalk 2
#15 DSGMach1
DSGMach1
    Themer
  • 264 posts
Posted 18 August 2012 - 02:36 AM
I just downloaded it and it worked fine on the rom I am using now. What are the steps you took exactly?
#16 Guest_BDH_*
Guest_BDH_*
Posted 18 August 2012 - 03:19 AM
By the way, looks sick DSG! Nice job!
