So both the volume up and down buttons are not responding on my Razr Maxx. They were sporadically not working for about 2 weeks before I lost all functionality. Now I can't use Recovery to try to wipe/flash/etc. since the volume buttons aren't responding.
I'm getting ready to fastboot back to stock using Matt's Utility using an app called "Quick boot" from the play store (which is a total godsend that an app can send me directly to AP fastboot), but I wanted to check if there was any other way that someone knew of to troubleshoot and/or fix the issue of the volume keys not working?
Thanks!
FYI - Rooted, Custom ROM (4.0.4/CM9 based), Safestrap 2.0, Razr Utility 1.81, on a Razr Maxx.
Volume Keys Not Working/broken. Any Fix Before Fastboot?
honeydesean
, Aug 24 2012 07:27 AM
volume broken razr maxx
No replies to this topic
Posted 24 August 2012 - 07:27 AM
RAZR Maxx - Two steps forward (Maxx>>>Droid1) and one step back (My bootloader! What have they done to you!?!)
Also tagged with one or more of these keywords: volume broken, razr, maxx
