For Droid HD v1.01 AND Arctic HD
(two separate files)
I am proud to present, Green Spectrum for Droid HD v1.01. It is basically a green theme. Nearly everything is green, if something isn't green its your imagination. Status bar has a few mods. For one, the signal bars are a little easier to read, they almost look like they do on stock GB. The 3g/4gLTE icons are a bit edited, I think they look cool Also the battery is in 10% visual increments. Meaning no percentage. I don't like 1%, makes me look at my battery more than my phone. I will probably release a 1% anyway in a future update (If you want it that bad now, its not hard to make or find one really). Anyways, let's get to the good stuffs.
I would like to thank the following...
Mattlgroff & Kebob - For DroidHD ROM
24v - Helping me because I need it that much.
Prstorero - For help
vtwinbmx - Help with softkeys
Badger50 - Flashed some test builds
W0017roid - Kept me company.
Twitter - Also kept me company
My mom - For having me
Google - For Android
What's Themed??
SystemUI
framework-res
Calender (sort of)
BlurCamera
Calculator
Contacts
Phone
Velvet.apk (Google Now)
LatinIME
Download Links
READ THIS CAREFULLY!
This theme works for BOTH DroidHD AND ArcticHD. Please download and flash the appropriate file. The only difference, is that the ArcticHD theme will keep softkeys disabled, whereas the DroidHD keeps softkeys enabled. If you want softkeys on ArcticHD, then flash the DroidHD theme. Simple, right?
Green Spectrum v1.0 (DroidHD) (Softkeys) -
Mirror -
Green Spectrum v.1.0 (ArcticHD) (No Softkeys) -
Mirror -
Green Spectrum reverter (Uninstalls my theme) (DroidHD) -
Mirror -
Green Spectrum reverter (Uninstalls my theme) (ArcticHD) -
Mirror -
Wallpaper (if my theme doesn't automatically set it) -
Install Instructions
- Download Green Spectrum (Or reverter if uninstalling) from link above
- Put on SD card
- Reboot in to recovery
- Wipe cache/dalvik
- Flash theme
- Reboot
- Green!
Changelog
September 8th 2012 - Initial Release
Screenshots
Neither me or anybody at DroidRZR is responsible if you screw up your phone! It's not that hard, my dog could probably do it.
