> > > > [Theme] Green Spectrum For Droid Hd And Arctic Hd! < < < <
#21
Posted 08 September 2012 - 08:36 PM
#22
Posted 09 September 2012 - 01:46 AM
Sent from my Amazon Kindle Fire using Tapatalk 2
#23
Posted 09 September 2012 - 03:03 AM
I'd probably just have to tweak a few settings and upload a separate file, but disabling soft keys is beyond my knowledge.
Alice you need to make three XML edits one in framework Res apk and two in system UI to turn off soft keys to upload them to Arctic HD. Pm me if you need help
#24
Posted 09 September 2012 - 03:53 AM
- vtwinbmx likes this
#25
Posted 09 September 2012 - 08:10 AM
Nice job Miss Alice. Your becoming quite good at all of this stuff. Any plans on making one for the Arctic HD? And to Mr. VTWIN...Your new Cm9Nitro rocks out. Tough deciding on which Rom to run. So I alternate. Gotta love the choices android gives us. Thanks again to all the wonderful Devs and themers out there :-)
As vtwin said above, all I need to do is changed 2 files and then it'll be compatible with Arctic HD (without enabling soft keys). I'd make a new theme for it from scratch but I don't like theming for a ROM I'm not running.
#26
Posted 09 September 2012 - 09:15 AM
#27
Posted 09 September 2012 - 09:38 AM
Fair enough Alice. I appreciate the reply. Keep up the great work :-)
Are you on Arctic HD? If so I just edited the theme so it should work on Arctic HD without enabling soft keys. Can I ask you to try it out?
#28
Posted 09 September 2012 - 09:40 AM
#29
Posted 09 September 2012 - 09:43 AM
Would be happy to try it out Alice. Thanks for the consideration :-)
OP is updated with links Please let me know if everything works.
#30
Posted 09 September 2012 - 09:49 AM
#31
Posted 09 September 2012 - 10:02 AM
#32
Posted 09 September 2012 - 10:06 AM
#33
Posted 09 September 2012 - 10:19 AM
Nice job Alice. Worked just fine. The only thing I'm noticing is that my menu keys are no longer lighting up. Certainly not a big deal to me. Thanks again for the theme....cause I do like it green :-)
That happens after a flash setting display toggle, auto Brightness should fix if not Ican tell Alice one more XML edit to make
#34
Posted 09 September 2012 - 10:20 AM
Figured it might be an XML lol. I think its setup to always be off cause the theme files are originally from DroidHD and that ROM has the hardkeys off and disabled.
#35
Posted 09 September 2012 - 10:24 AM
#36
Posted 09 September 2012 - 10:25 AM
Thanks Twin. I tried the brightness toggle, but to no avail. I'm sure you and Alice will figure it out :-)
Crap I'll send her XML edit now sorry
#37
Posted 09 September 2012 - 10:28 AM
Theres no figuring to do, Vtwin tells me how to fix it and I do it XDD.
#38
Posted 09 September 2012 - 10:29 AM
#39
Posted 09 September 2012 - 10:36 AM
No biggie buddy. I thank you 2 for taking care of us all :-)
Added download links to OP. Added "R1" to the end of it so you don't get it mixed up
#40
Posted 09 September 2012 - 10:54 AM
