Help. I think I bricked my RAZR M...
29 replies to this topic
#1 akmjolnir
akmjolnir
  • 18 posts
  • Current Device(s):XT907
Posted 07 May 2014 - 04:06 PM
Rooted, but not unlocked.
Running Rage 1.4 through Safestrap.
I was switching between stock ROM and RAGE (custom ROM) in Safestrap so that I could wipe cache, dalvik, and reset it due to some performance lagging issues.  I wasn't paying attention and very well may have had the stock ROM activated and wiped it.
When I try to boot up my phone it shows the Rage logo, then the Safestrap menu page for about 5 seconds.  Safestrap status is "disabled" and neither of the two buttons "Recovery" and "Continue" are responsive.  After about 5 seconds it goes to a blank screen and the phone shuts off.
I tried pressing the power button + volume buttons to go into recovery mode, but it only powers on and produces the same results as above.
Any suggestions? Tips? Tricks?
#2 johnthehillbilly
Posted 07 May 2014 - 04:18 PM
What you need to do is use RSDLite or Sam's House of Moto and the latest FXZ file to flash stock back to your phone...... Then you will be good to go.....
But please do yourself a favor and read read read and fully understand the process prior to running..... And ask questions before doing anything......:)
House of moto...
  • SamuriHL and TwentyFourVee like this
#3 akmjolnir
akmjolnir
  • 18 posts
Posted 08 May 2014 - 03:42 AM
Thanks for the response, I appreciate it.
#4 akmjolnir
akmjolnir
  • 18 posts
Posted 08 May 2014 - 04:17 PM
Usage:
o) Your phone MUST be in AP Fastboot mode.  Try holding volume down and pressing the power button when the phone is off.
In reading the directions I came to what I think may be a snag.  In order to ensure the phone is in AP Fastboot mode I need to enter the recovery menu, but when I hold the Power + Volume Down buttons it just brings me to the Rage loading screen, then the Safestrap menu, and then shuts down.
#5 johnthehillbilly
Posted 08 May 2014 - 04:20 PM
You need to be powered completely off .... Then hold power volume up and volume down
#6 akmjolnir
akmjolnir
  • 18 posts
Posted 08 May 2014 - 04:26 PM
Yeah, when I do that (charged battery, phone off) it launches the Rage M screen, then Safestrap menu screen, then shuts off.  I'll try to proceed with the reinstallation of the stock ROM and keep my fingers crossed.
#7 RikRong
RikRong
    Cap'n Slow
  • 2,117 posts
  • LocationNoDak
  • Current Device(s):Pixel 7
Posted 08 May 2014 - 05:01 PM
You need to have the phone UNPLUGGED from the computer, otherwise it will reboot into the OS every single time.  If you deleted your stock ROM, then SS is functionally gone, too.  You won't be able to flash or restore the stock ROM, without RSDing it.
  • livinginkaos likes this
#8 livinginkaos
Posted 08 May 2014 - 05:05 PM
That's a mistake I make often. It's always the simple things.... Well almost always.
Sent from my S-Offed One M8
  • johnthehillbilly likes this
#9 RikRong
RikRong
    Cap'n Slow
  • 2,117 posts
  • LocationNoDak
Posted 08 May 2014 - 05:11 PM
Yeah, I can't count how many times I've done it.  "Stupid, phone, why won't you stay off!"  Ohhh, cord's in.
  • johnthehillbilly and livinginkaos like this
#10 akmjolnir
akmjolnir
  • 18 posts
Posted 08 May 2014 - 05:31 PM
I've followed the instructions for
Can you expand on RSDing it?  (I'm doing this for the first time, so bear with me...)
I've installed all the required files/apps from the link in post #2, and the other files associated with it.  So, in my HouseOfMoto folder I opened HouseOfMoto.bat and HouseOfMoto.sh via Terminal (I'm on a Mac), and I hit a dead end.
When I open the .sh file I get this:
and don't know what to enter; nothing seems to happen when I type in stuff.
When I open the .bat file I get this:
and nothing happens when I type.
I'm pretty much out of ideas here.
#11 RikRong
RikRong
    Cap'n Slow
  • 2,117 posts
  • LocationNoDak
Posted 08 May 2014 - 05:41 PM
RSDing is just using HoM or RSD to flash the phone, pretty much like you're doing. As for the issues you're running into, I'm not really sure what to tell you. I'm not great with the technical stuff yet, hopefully someone that is smarter will chime in.
#12 johnlgalt
johnlgalt
    Antidisestablishmentarianist
  • 7,296 posts
  • Location3rd Rock
Posted 08 May 2014 - 05:42 PM
You can't use the bat file on Darwin machines - it's a windows thing.
#13 johnlgalt
johnlgalt
  • 7,296 posts
  • Location3rd Rock
Posted 08 May 2014 - 05:43 PM
And since you're actually using HoM, your best bet is to probably re-read the HoM thread again.  You're missing a step.
  • RikRong likes this
#14 akmjolnir
akmjolnir
  • 18 posts
Posted 08 May 2014 - 05:53 PM
I've reread the instructions in Post #1 on the HoM page and still seem to be coming up with the same result.
#15 johnlgalt
johnlgalt
  • 7,296 posts
  • Location3rd Rock
Posted 08 May 2014 - 05:56 PM
In that screenshot, it says FXZ: and nothing is listed.
Please read the extracting the FXZ part again and make sure that yours matches what is there.
#16 akmjolnir
akmjolnir
  • 18 posts
Posted 08 May 2014 - 06:14 PM
I followed the directions regarding extracting the FXZ parts and this is what I originally had (still do after rereading it all again) in my HoM folder:
#17 akmjolnir
akmjolnir
  • 18 posts
I appreciate the troubleshooting help from you folks, btw.
#18 johnlgalt
johnlgalt
  • 7,296 posts
  • Location3rd Rock
Posted 08 May 2014 - 06:28 PM
lol oops- I took a second lookk ath e .sh pic - you need to enter 1, of course - that's your device, eh?
From the HoM thread:
o) On first run:
     Enter your device model (xt926, xt875, etc)
#19 akmjolnir
akmjolnir
  • 18 posts
Posted 08 May 2014 - 06:34 PM
o) On first run:
Yes, I have an xt907.  I did enter 1, and it didn't do anything:
#20 johnlgalt
johnlgalt
  • 7,296 posts
  • Location3rd Rock
Posted 08 May 2014 - 06:59 PM
And when you hit 1 the phone is connected again, right?
Not sure what is going on - best go to the HoM thread
