Help. I think I bricked my RAZR M...
#21
Posted 09 May 2014 - 03:03 AM
Sent from my S-Offed One M8
Sig by
#22
Posted 09 May 2014 - 04:21 AM
My phone is connected via the OEM charge cable. I'll head over to the HoM thread. Thanks for your help guys.
#23
Posted 09 May 2014 - 06:17 AM
You need to run it as sudo.
#25
Posted 09 May 2014 - 06:52 AM
Yea, it always is. What's happening is it's trying to run a command to get a list of the scripts in the FXZ directory and it's failing cause it doesn't have perms. Run it as SUDO and it should work properly.
#26
Posted 09 May 2014 - 07:07 AM
Since I've never run it on a non Windows computer, that never occurred to me.
#27
Posted 09 May 2014 - 10:39 AM
Where/when do I type in the sudo command (it's just "su", then I enter my password IIRC)?
#28
Posted 09 May 2014 - 10:40 AM
Right so in your terminal you just do:
su
<enter pwd>
./HouseOfMoto.sh
And that should hopefully get you up and running. If not, we can short circuit some of this for you.
#29
Posted 09 May 2014 - 10:49 AM
I have to literally run back to work, but it's still not working. I'll wait until I have more time to send more thorough info/pics of the terminal windows.
Appreciate the help. Have a great weekend.
#30
Posted 09 May 2014 - 10:55 AM
If it's still not working then something isn't set up right. You say you're on a Mac. It's been mildly tested on Macs before, but, I may need to know more about your particular environment. If not, I can give you a work around most likely where we can edit the KEEP_DATA script and run it directly. You just have to add a set fastboot line near the top and point it at the path to the fastboot command in the Darwin folder. I can help with that if we have to go that route.
