Posted 28 September 2012 - 07:30 PM
Turned the screen on after work yesterday and it was acting like I had the HDMI cable plugged in(stuck in landscape and asking what mode I prefer), but it has not been for a few days.
2.58MB 4 downloads
I actually do use port plugs- I really do not like how all 3 ports are open and on the top exposed.
2.56MB 3 downloads
Anyone else use these?? I really had fun finding that micro HDMI port cover, and now that might be the problem?
Got these from here:
Anyway, I got home, powered the phone down, blew out the ports with Dust Remover in a can. Powered back up. All seemed good.
For about 24 hrs. I did leave the plugs out during this time and used a magnifying glass to check the ports.
I went to plug into my original, factory, Moto wall charger today and it all started again. Even when unplugging it. Once it starts a reboot does not affect it.
Any ideas? My main question is how does the phone detect HDMI? By way of a physical switch that it 'feels' when a plug is in, or by way of completing the electrical circuit when plugged. Either way I dont know why plugging my charger would activate it, besides, it had been off all cables for hours the first time it happened.
Posted 28 September 2012 - 11:52 PM
Posted 30 September 2012 - 04:42 PM
Posted 30 September 2012 - 05:26 PM
Hope it's not a refurb.
Anyway, I still have some questions.
Is it probable my above mentioned port plugs caused this? I really don't want it to happen again.
Another question: Is there a recommended maximum length HDMI cable? The one I have has been working perfectly since I got the phone in May, but I don't know if being too long would cause it to whig out like this(To clarify it still works perfectly when plugged in, just still thinks it plugged in randomly even hours after).
Don't want any problems with the replacement.
Posted 30 September 2012 - 05:38 PM
Posted 30 September 2012 - 06:23 PM
Sent from the cutting edge of my Droid RAZR MAXX
On a side note, where did u get those plugs for the ports?
Sent from my peanut butter and jelly sandwich
Posted 30 September 2012 - 06:34 PM
Check it out here: http://youtu.be/vfRxQDUEHtI
The plugs were fromOn a side note, where did u get those plugs for the ports?
I have left them out since this started just in case.
Posted 09 October 2012 - 02:53 PM
there you have connect HDMI
just make it unchose and it will do the trick,
just for u to know if you have case the cover the slots
its make the razr thinks that hdmi plugged, other way its problem
and lab told me it cant be fixed, maybe corosia, or maybe its falls and that what happened
Posted 22 October 2012 - 04:03 PM
Been running Refurb replacement a few weeks now, all is good EXCEPT...
Battery!! Battery info shows good health, but definitely not lasting as long. Same setup, used all the great charging ideas.. Good thing I have tha MAXX!
Also tagged with one or more of these keywords: HDMI, Port plugs, topicover
