Deodexed 6.7.247
Posted 01 October 2012 - 04:02 PM
All you have to do is:
1. Download zip file
2. Place zip on sdcard-ext
3. Boot into CWM recovery via bionic bootstrapper
4. Scroll to "install zip from sdcard"
5. Scroll to "choose zip from sdcard"
6. Find deodexed zip and choose it
7. Once done flashing, press "reboot system now"
8. It will run through "optimizing applications" (DON'T RESET OR PULL BATTERY!)
9. ENJOY DEODEXED 247! :-)
Thanks go to: DLuke, John L. Galt + Twinkyz1979 THANKS GUYS!
Download:
(while on 247)
As always I, nor anyone here, are responsible for you, your phone or what you do to it! :-P So follow directions and do it right the first time... :-)
-T3T3droid
if you like my work
- mhous33, johnlgalt and DLuke like this
Posted 01 October 2012 - 04:03 PM
Razr Maxx
Posted 01 October 2012 - 04:29 PM
**So ive always held out on adding a donate link because this is just something i do for enjoyment.. but i have received a few requests recently to add one.. so if you enjoy my work and would like to buy me a beer or put some gas in my car, that would be very much appreciated.. but please continue to freely enjoy my mods without any feeling of obligation what-so-ever.. the last thing i want by adding this is for people to stop using my mods because they fell obligated.. Thanks
Posted 02 October 2012 - 09:19 AM
Posted 02 October 2012 - 10:09 AM
Posted 03 October 2012 - 04:55 AM
Posted 03 October 2012 - 06:58 AM
Posted 03 October 2012 - 07:54 AM
requires bootstrap... i just figured this out yesterday
That's sort of what I was thinking but thanks. I think I'll stick with SS and stock 247 on the unsafe side and do my playing on the safe side as was intended by the Bionic Gods.
Posted 03 October 2012 - 09:20 AM
ok so heres the deal...the files in this zip are un-odexed meaning the classes.dex files of the apk's are placed back into the apk from the .odex file. this makes it so that you can edit the files with less of an issue. instead of having blah.apk AND blah.odex you simply have blah.apk. if for instance you want to flash the 1% battery mod by Dluke on stock, it wont work because of that odex file. there is no need to wipe or format anything when flashing this so theres no worry about it not booting in bootstrap. all its doing is swapping the files out. without these zips you wouldnt have themeing or the roms that the Bionic Gods make for you. so basically if your not a moder or themer or developer then you dont need this...
No disrespect, just elaborating.
- johnlgalt likes this
Posted 03 October 2012 - 09:48 AM
and provide links
n stuff
this process is slightly different than the normal romming scene. atleast for me.
Posted 03 October 2012 - 11:24 AM
t3t3 can you write up a guide on how to re-odex so that we can go back to normal if we so desire?
and provide links
n stuff
ill see what i can do. ill try to make a flashable zip to reverse the process like we talked about. shouldnt be too hard
- johnlgalt and mtbrgeek like this
Posted 03 October 2012 - 05:47 PM
- T3T3droid likes this
Posted 04 October 2012 - 04:23 AM
Thanks for the info, I understand the doedexed stuff from the DX days. I was asking since I was thinking of staying stock. I know that on the safe side you basically have a copy of most of the system APKs and I'm guessing that they have already been deodexed since most of them are themed. But thanks again for the information and all the hard work you put into making our Bionics soooooo much better.
Cheers
Posted 04 October 2012 - 08:27 AM
and provide links
n stuff
Guide:
1) Download and install HoB (which I'm assuming you already have since you're on 7.7.247 to begin with).
2) Use INSTALL method to install .247 if you have not messed with WebTop, or use REINSTALL method to reinstall if you've modified anything in WebTop.
This will be a lot easier than trying to fudge around with with a script to reverse what you did, yada yada yada.
Alternate (and easier) method (provided you made a Nandroid backup):
1) Restore Nandroid backup of system you made prior to installing deodexed system files (you did make a Nandroid backup, right?)
No need to host a third set of files here for going back to stock (odexed) system files since there is already a method, even if you did not make a Nandroid backup.
- T3T3droid, mtbrgeek and csantarcangelo like this
Posted 04 October 2012 - 10:51 AM
Guide:
Thanks for giving them that John! Much easier
Posted 04 October 2012 - 10:52 AM
Cheers
Any time my friend and thanks for the support
