I am a new member and the first thing I tried to do is download the motochopper tool so that I can root my Droid Razr X912. But, after downloading it from several sites, the zip file never unzippes because it says there is an error in the zip file. I obtained the tool from several different download sites and also tried 7-zip. It says "cannot open motochopper.zip as archive". The regular windows zip utility doesn't work either. Does anyone know what's wrong?
1 reply to this topic
Posted 23 July 2014 - 01:48 PM
Posted 23 July 2014 - 03:09 PM
First off, Motochopper will not work. You either need Razr Blade or motosaferoot. I personally would use motosaferoot because it is much simpler.
Sent from my S-Offed One M8
Sig by
Also tagged with one or more of these keywords: motochopper
Legacy Devices →
VZW Droid Razr/Razr Maxx HD [XT926-CDMA/LTE] →
VZW Droid Razr/Razr Maxx HD General [XT926] - {Q&A, Discussion} →
Unlocked 9.30.1 Root possible?Started by Slickademo , 18 Dec 2013 9.30.1, Root, motochopper, xt926 and 1 more... |
