4 replies to this topic
Posted 12 November 2012 - 12:29 PM
I recently tried to put a new rom on my dads razor maxx. when in recovery mode it wouldnt let me install from sd because safe mode was enabled, so i disabled in recovery mode. now it wont let me go into recovery mode (it goes in to recovery mode just not the normal one.... ill put a picture below) at all but im still rooted and can boot the phone up all the way..... what do i need to do to fix this?
Posted 12 November 2012 - 12:43 PM
The picture above is Moto Recovery. For Roms you need to be in Safestrap recovery. Are you seeing the safestrap splash screen after the red M splash when rebooting? This should allow you to hit menu at that time and go into safestrap recovery. What version of Safestrap are running??
You must have safe side enabled to flash Roms in Safestrap recovery
Posted 12 November 2012 - 12:50 PM
no, it doesnt boot a safestrap recovery.. it boots up and the only way i can even get close is to use rom manager and boot into it that way but it just loads the moto recovery.
I am running safestrap version 2.0
Posted 12 November 2012 - 12:56 PM
Boot up your phone. Go into Safestap app. uninstall recovery then reinstall and reboot
Posted 12 November 2012 - 12:57 PM
yay! it worked... it was so simple, i cant believe i didnt think of it
thank you
thank you
- Memnoch73 likes this
Also tagged with one or more of these keywords: razor maxx
Legacy Devices →
VZW Droid Razr General [XT912] - {Q&A, Discussion} →
Installing Webtop 3 Onto Custom Rom?Started by Shawn! , 12 Nov 2012 razor maxx |
Legacy Devices →
VZW Droid Razr Help [XT912] →
Mms Not Working On New RomStarted by Shawn! , 12 Nov 2012 razor maxx |
