Talk about little or no expirence, I had no idea it would be this complicated. I'm in the live session running off the flash drive at the moment. It's not what I was hoping for that's for sure. I just keep running into walls. None of the files I placed on the flash drive are visible. Probably bull$#!+ from microsoft making the files unreadable outside the windows environment or something to do with it being on a flash drive. Thankfully I can see my hard drives and my user data from windows, so I can access the files there. Unforntuantly the HouseOfMoto.sh file does not run as I expected, it just brings up the script itself. Which is not useful in this case.
I finally found the terminal application and even navigated to files I copied over to the Unbuntu live file system. I placed the files in the music directory because I can not figure out how to move up and down the directories. cd.. didn't work. I would hate using this operating system everyday. Yet when I try to run the .sh script the OS does not understand what I'm talking about. It will not excute or run in any fashion. I know this is all from my lack of understanding of how this operating environment works.
Perhaps since I've copied the files while the live file system is running it will let me change the properties so the OS will stop blocking the script.
