After installing SS 3.05 and creating rom slots I am getting low volume messages constantly. My slots are 2gb. I believe the threshold for that message comes when internal memory is under 2gb. I have the vast majority of my apps on ext. SD. Is there a way to eliminate that annoying message or change the threshold at which it appears? Or should I just erase everything and start over and make my slots 3gb?
Changing "low volume" threshold
hey_poolboy
, Dec 08 2012 02:49 PM
memory warning low volume internal storage space low
5 replies to this topic
Posted 08 December 2012 - 02:49 PM
Sent from my Droid Razr Maxx running a different ROM nearly every day.
Posted 08 December 2012 - 03:09 PM
That message comes up when you have less than 1 gb left on the internal sd card. If you made 2 3 gb slots, considering the 600 mb for each system and 200 for each cache, that will put you under the gb threshold. If you're installing most apps to the external sd, then I would suggest making 1 gb slots. As far as I know there is no way to change the threshold.
Sent from my DROID RAZR
Posted 08 December 2012 - 03:44 PM
Thanks. After a little more digging around that seems to be the general consensus. I only have 2 2gb slots, and I did make sure to remove my old SS folder, but it looks like my SS folder is the bulk of my problem @ 6.4 gb. Each of the "2gb" slots takes up 2.8GB. I just wasn't sure during setup just how large the slots should be. Looks like I'll be backing up and deleting slots and re-doing them tonight.
Posted 08 December 2012 - 04:42 PM
Also, of you're installing ICS roms, then any apps you move to sd will probably wind up on the internal sd card. Check your .androidsecure directory on both the internal and external to be sure.
Posted 10 December 2012 - 08:54 AM
You were correct on both counts. I backed up my roms, deleted my slots and started over from scratch with 1gb slots. All is well and now I have Flick5, Arctic HD, and one of the evolution roms loaded up!
Posted 11 December 2012 - 03:29 PM
Well I only get that message when on a ics rom.
Also tagged with one or more of these keywords: memory, warning, low volume, internal storage space low
Legacy Devices →
VZW Droid Bionic [XT875-CDMA/LTE] →
Droid Bionic General [XT875] - {Q&A, Discussion} →
2 Different Internal Storage Space Values?Started by Endbringer42 , 15 Apr 2013 storage, memory |
Legacy Devices →
Swap And Or Ram?Started by glocke , 19 Sep 2012 speed ram, memory, fast |
Legacy Devices →
VZW Droid Razr General [XT912] - {Q&A, Discussion} →
Memory Set UpStarted by freestylesno , 18 Mar 2012 memory, SD, storage |
